Discuss
Front right burner always in dual mode
 in
The front left element on my Whirlpool Gold range (ceran glass cook top) has two heat settings on the dial,
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Front right burner always in dual mode
  #1 (permalink)
Old 08-04-2008, 06:19 PM
sonic sonic is offline
Junior Member
sonic is on a distinguished road
Default Front right burner always in dual mode
Model Number: GJSP84900   Brand: Whirlpool   Age: 1 - 5 years
The front left element on my Whirlpool Gold range (ceran glass cook top) has two heat settings on the dial, single and dual. The problem is that even on the single setting both elements heat up as if dual mode is selected.
I'm guessing the switch for dual / single mode is broken but am wondering if the element could be the cause. I'd ohm it out but haven't figured out how to get at the switches or the elements.
Any one know where I could find disassembly instructions and part numbers?
Thanks in advance
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 08-05-2008, 02:10 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Most likely the problem is a bad switch. You can test the switch according to the wiring diagram. In order to access the switch remove the rear cover form the control panel.
- The part number for the dual switch is AP3182987
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Left Front Burner Won't Come On ptom Oven Repair (including Ranges and Cooktops) 0 07-29-2008 08:43 AM
Dual Burner switch on the blink again macmaxim Oven Repair (including Ranges and Cooktops) 4 07-17-2008 02:40 PM
Right front (large) burner failed karamba Oven Repair (including Ranges and Cooktops) 0 07-03-2008 09:36 PM
Right front burner will not work Arod Oven Repair (including Ranges and Cooktops) 3 05-03-2008 05:08 PM
Right Front Burner Doesn't Work Babdiver Oven Repair (including Ranges and Cooktops) 8 05-01-2008 07:50 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
