| » Thermador display is very dim |
Guys,
I just performed the capacitor replacement and I can confirm it worked perfectly. Furthermore, the only capacitor that needs to be replaced is the smaller 68uf that is in between the larger 470's on the side. Replacing the 470's made no change for me. The display went bright only after replacing the 68uf. Also, there's no need to send off for these capacitors. Your local radio-shack has them. Mine was out of stock on the 68uf, but I used a 100uf which worked just fine. Keep rockin. Thanks for the info. |
The display on our oven is very dim, the only part of the display that shows anything is the clock, the oven still seems to work.
I was going to order the touchpad because the connections seemed a little sloppy in back.If I change that, the problem should be fixed? TIA[/quote] |
| Display Modes | |
| Thermador Cooktop Sparking | Matt Schauer | Oven Repair (including Ranges and Cooktops) | 16 | 06-30-2009 09:01 PM |
| Dead Display | d-man | Oven Repair (including Ranges and Cooktops) | 0 | 09-12-2007 05:46 PM |
| Thermador Free Standing Range | SpaceAce | Oven Repair (including Ranges and Cooktops) | 1 | 08-14-2007 01:28 AM |
| Doesn't Run, No Display. | Singer | Dishwasher Repair | 4 | 08-13-2007 01:27 PM |
| Only 8's showing on the erc display | BruceL | Oven Repair (including Ranges and Cooktops) | 1 | 07-22-2007 11:20 PM |
