| » Thermador display is very dim |
Good idea and I wish it would but unfortunately it's not going to work.
__________________
Professional appliance repair in Orange County, California. |
Quote:
g5reality,
All your questions should be addressed to the Appliance Parts Pros customer service (877-477-7278). Gene.
__________________
Gene,
My oven is a GSC30CV. First my display went out. I don't recall it getting dimmer. I sent the display off to get repaired since the part is no longer available. They suggested I replace the power relay, which I did with part #AP2837330. That worked for about a month, then the display started getting dim. Now in the right light I can read the time, but not the temp. When it was going dim I could flip the breaker and give it a few minutes and then flip the power back on and the display would work long enough to set the temp. Now that doesn't work. Will the control kit you mention here work with my oven? If not, is there something else I should be doing? |
Hi Derek,
The kit listed above is not good for your range. The only way you can try is contact people from PCBR.BIZ and ask if they can rebuild the old part. If they can not then you have to look for a new range. Gene.
__________________
Thanks for answering.
I did things out of order. I already sent the display in to be repaired/rebuilt, when that didn't work I replaced the power relay. That worked for about a month. I am going to replace the power board again and check the wiring. Are you saying that the "dimming" is related to the display (not the power relay) and I should send it off to get repaired/rebuilt again? If another display worked with the GSC30CV, I would love to get a new one instead of having to deal with sending in the part to get repaired. |
Hi Derek,
Based on my experience, "dimming" is related to display boards (couple capacitors on the board). I can not provide more accurate information because I never fixed them myself. Parts like displays designed for some specific models and they are not interchangeable. Gene.
__________________
Quote:
Quote:
__________________
| Display Modes | |
| Thermador Cooktop Sparking | Matt Schauer | Oven Repair (including Ranges and Cooktops) | 16 | 06-30-2009 09:01 PM |
| Dead Display | d-man | Oven Repair (including Ranges and Cooktops) | 0 | 09-12-2007 05:46 PM |
| Thermador Free Standing Range | SpaceAce | Oven Repair (including Ranges and Cooktops) | 1 | 08-14-2007 01:28 AM |
| Doesn't Run, No Display. | Singer | Dishwasher Repair | 4 | 08-13-2007 01:27 PM |
| Only 8's showing on the erc display | BruceL | Oven Repair (including Ranges and Cooktops) | 1 | 07-22-2007 11:20 PM |
