Discuss
Frigidaire Door Lock and F9 error code
 in
I received this range from a friend, so not sure of what age it is. I was trying to bake
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Frigidaire Door Lock and F9 error code
  #1 (permalink)
Old 07-10-2010, 12:58 PM
Junior Member
chispaluz is on a distinguished road
Default Frigidaire Door Lock and F9 error code
Model Number: FGFB74BJBB   Brand: Frigidaire   Age: 1 - 5 years
I received this range from a friend, so not sure of what age it is. I was trying to bake with it, but the lock light began to blink, the oven door locked up, and the bake function is not working. I was able to get the door open, but the door lock switch is stuck out. I tried pushing in the oven light button and pressing cancel at the same time (I saw that in a prior posting). Another code "dr" also came up. Any ideas?
Related Models
Frigidaire FGFB74BJBB RANGE
Frigidaire FGFB75DBA Frigidaire/gas Range
Frigidaire FGFB75DBB Frigidaire/gas Range
Frigidaire FGFB75DBC Frigidaire/range
Frigidaire FGFB75DBE Frigidaire/range
Frigidaire FGFB75DBF Frigidaire/range
Frigidaire FGFB75DBG Frigidaire/gas Range
Frigidaire FGFB75DCA Frigidaire/gas Range
Frigidaire FGFB75DCB Frigidaire/range
Frigidaire FGFB75DCC Frigidaire/range
Frigidaire FGFB75DQA Frigidaire/gas Range
Frigidaire FGFB75DQB Frigidaire/gas Range
Frigidaire FGFB75DQC Frigidaire/range
Frigidaire FGFB75DQE Frigidaire/range
Frigidaire FGFB75DQF Frigidaire/range
Frigidaire FGFB75DQG Frigidaire/gas Range
Frigidaire FGFB75DSA Frigidaire/gas Range
Frigidaire FGFB75DSB Frigidaire/gas Range
Frigidaire FGFB75DSC Frigidaire/range
Frigidaire FGFB75DSE Frigidaire/range
Frigidaire FGFB75DSF Frigidaire/range
Frigidaire FGFB75DSG Frigidaire/gas Range
Frigidaire FGFB79GBA Frigidaire/range
Frigidaire FGFB79GBB GAS RANGE
Frigidaire FGFB79GBC GAS RANGE
Frigidaire FGFB79GBD GAS RANGE
Frigidaire FGFB79GBE GAS RANGE
Frigidaire FGFB79GBF GAS RANGE
Frigidaire FGFB79GCA Frigidaire/range
Frigidaire FGFB79GCB GAS RANGE
Frigidaire FGFB79GCD GAS RANGE
Frigidaire FGFB79GCE GAS RANGE
Frigidaire FGFB79GCG GAS RANGE
Frigidaire FGFB79GCH GAS RANGE
Frigidaire FGFB79GQA Frigidaire/range
Frigidaire FGFB79GSA Frigidaire/range
Frigidaire FGFB79GSB GAS RANGE
Frigidaire FGFB79GSC GAS RANGE
Frigidaire FGFB79GSD GAS RANGE
Frigidaire FGFB79GSE GAS RANGE
Frigidaire FGFB79GSF GAS RANGE
Frigidaire FGFB82DSA Frigidaire/range
Frigidaire FGFB86DBA Frigidaire/gas Range
Frigidaire FGFB86DBB Frigidaire/range
Frigidaire FGFB86DBC Frigidaire/range
Frigidaire FGFB86DCA Frigidaire/gas Range
Frigidaire FGFB86DCB Frigidaire/range
Frigidaire FGFB86DCC Frigidaire/range
Frigidaire FGFB86DCD Frigidaire/range
Frigidaire FGFB86DCE Frigidaire/range
Frigidaire FGFB86DCG Frigidaire/range
Frigidaire FGFB86DCH Frigidaire/range
Frigidaire FGFB86DQA Frigidaire/gas Range
Frigidaire FGFB86DQB Frigidaire/range
Frigidaire FGFB86DQC Frigidaire/range
Frigidaire FGFB86DSA Frigidaire/gas Range
Frigidaire FGFB86DSB Frigidaire/range
Frigidaire FGFB86DSC Frigidaire/range
Frigidaire FGFB9100ES0 Frigidaire/dryer
Frigidaire FGFB9200ES0 Frigidaire/dryer
Frigidaire FGFBMZ96FCA Frigidaire/gas Range
Frigidaire FGFBMZ96FCB Frigidaire/range
Frigidaire FGFBMZ96FCC Frigidaire/gas Range
Frigidaire FGFBZ90GCA GAS RANGE
Frigidaire FGFBZ90GCC GAS RANGE
Frigidaire FGFBZ90GCE GAS RANGE
Frigidaire FGFBZ90GCF GAS RANGE
Frigidaire FGFBZ90GCG GAS RANGE
Frigidaire FGFBZ90GCH GAS RANGE
Frigidaire FGFL66ASA Frigidaire/gas Range
Frigidaire FGFL66ASB Frigidaire/range
Frigidaire FGFL66ASC Frigidaire/gas Range
Frigidaire FGFL66ASD Frigidaire/gas Range
Frigidaire FGFL67DBA Frigidaire/gas Range
Frigidaire FGFL67DBB Frigidaire/range
Frigidaire FGFL67DBD Frigidaire/range
Frigidaire FGFL67DBF Frigidaire/range
Frigidaire FGFL67DBG Frigidaire/range
Frigidaire FGFL67DBH Frigidaire/range
Frigidaire FGFL67DBJ Frigidaire/gas Range
Frigidaire FGFL67DBK GAS RANGE
Frigidaire FGFL67DBL GAS RANGE
Frigidaire FGFL67DCA Frigidaire/gas Range
Frigidaire FGFL67DCB Frigidaire/gas Range
Frigidaire FGFL67DCC Frigidaire/gas Range
Frigidaire FGFL67DCD Frigidaire/range
Frigidaire FGFL67DCE Frigidaire/range
Frigidaire FGFL67DCF Frigidaire/range
Frigidaire FGFL67DCG Frigidaire/range
Frigidaire FGFL67DCH Frigidaire/gas Range
Frigidaire FGFL67DCJ Frigidaire/range
Frigidaire FGFL67DCK Backguard
Frigidaire FGFL67DCL GAS RANGE
Frigidaire FGFL67DCM GAS RANGE
Frigidaire FGFL67DCN GAS RANGE
Frigidaire FGFL67DQA Frigidaire/gas Range
Frigidaire FGFL67DQB Frigidaire/range
Frigidaire FGFL67DQD Frigidaire/range
Frigidaire FGFL67DQF Frigidaire/range
Frigidaire FGFL67DQG Frigidaire/range
Frigidaire FGFL67DSA Frigidaire/gas Range
Frigidaire FGFL67DSB Frigidaire/range
Frigidaire FGFL67DSD Frigidaire/range
Frigidaire FGFL67DSF Frigidaire/range
Frigidaire FGFL67DSG Frigidaire/range
Frigidaire FGFL67DSH Frigidaire/range
Frigidaire FGFL67DSJ Frigidaire/gas Range
Frigidaire FGFL67DSK GAS RANGE
Frigidaire FGFL67DSL GAS RANGE
Frigidaire FGFL67HBA GAS RANGE
Frigidaire FGFL67HBB GAS RANGE
Frigidaire FGFL67HBC GAS RANGE
Frigidaire FGFL67HBD GAS RANGE
Frigidaire FGFL67HBE GAS RANGE
Frigidaire FGFL67HBF GAS RANGE
Frigidaire FGFL67HBG GAS RANGE
Frigidaire FGFL67HBH GAS RANGE
Frigidaire FGFL67HBJ GAS RANGE
Frigidaire FGFL67HCA GAS RANGE
Frigidaire FGFL67HCB GAS RANGE
  #2 (permalink)
Old 07-10-2010, 01:03 PM
Junior Member
Default
I didn't mention in the post that an "F9" code also comes up with a loud beeping sound.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
frigidaire error code F10 - not listed in your error codes Skully26 Oven Repair (including Ranges and Cooktops) 2 02-16-2010 05:29 AM
Error code-door lock Ellay Washer Repair 5 08-11-2009 02:37 PM
F9 error code - lock dpalomo Oven Repair (including Ranges and Cooktops) 0 03-24-2009 04:04 PM
error code E1 F5 door lock? sholmer963@aol.com Oven Repair (including Ranges and Cooktops) 3 01-02-2009 06:26 AM
F9 code Oven turns off,lock light turns on,door does not lock darling132 Oven Repair (including Ranges and Cooktops) 1 11-12-2008 03:06 PM
