| » Bake Element Voltage |
Model Number: KEDT105WBL0 Brand: Kitchen Aid Age: More than 10 years
Hello
Could someone tell me what the voltage across the bake element should be. I am reading 115vac steady. I replaced the element but the oven takes a long time to reach temp. The old element was bad. The replacement elements physical diameter is 3/4 the original. I do not know if I have a voltage issue or if the element I have is not correct. Also where could I find a schematic for this range. Thank you in advance for all replys Joe Ads By Google Related Models |
Here is the parts breakdown
Replacement parts for WHIRLPOOL KEDT105WBL0 | AppliancePartsPros.com Here is the tech sheet for this unit http://www.servicematters.com/docs/w...%203148392.pdf You should have 240 volts across the element when on.
__________________
| Display Modes | |
| Oven bake/broil not working after bake element replacement | J Justin | Oven Repair (including Ranges and Cooktops) | 1 | 11-05-2009 04:36 PM |
| Replaced bake element, now won't bake/broil | mvwa | Oven Repair (including Ranges and Cooktops) | 0 | 10-18-2009 12:55 PM |
| No voltage at the Bake Element | alron2 | Oven Repair (including Ranges and Cooktops) | 2 | 06-09-2009 02:33 PM |
| Should there be any voltage on bake element leads in my oven? | el camino | Oven Repair (including Ranges and Cooktops) | 1 | 04-11-2009 08:31 AM |
| No voltage to lower heater element | buzz | Oven Repair (including Ranges and Cooktops) | 2 | 12-19-2007 07:40 AM |
