My electric range oven has irratic temperature. Sometimes it will keep heating and not shut off (themometer has read 600 degrees!). At other times the oven will just shut off on it's own, even before the timer has expired. The model number entered above 114961F is the only legable number on the plate (only plate I could find is located under the front left top buring element.
