Discuss
GE Profile Electric Slide In Range - Door Locked
 in
We owned this range for about 3 1/2 years and as usual, when it's dirty, I clean it
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » GE Profile Electric Slide In Range - Door Locked
  #1 (permalink)
Old 08-01-2008, 10:33 AM
my appliance my appliance is offline
Junior Member
my appliance is on a distinguished road
Unhappy GE Profile Electric Slide In Range - Door Locked
Model Number: JS96850F3SS   Brand: GE   Age: 1 - 5 years
We owned this range for about 3 1/2 years and as usual, when it's dirty, I clean it via the self-cleaning oven for 4 hours. Well, I did the same thing this time and after it completed the cleaning process, the door kept flashing "locked". This is the mode it has been in for 2 days. We unplugged it but nothing happened when when plugged it back in. For about 3 seconds the electronic pad lit up everything that's available then it went back to the "locked" position. The oven door is closed and the clock is correct. I tried turning on and off the timer, but that doesn't work. I have tried to turn the self-cleaner on again, but it won't do that either. It just goes back to the "locked" mode. There is no latch so all is electronic. Any ideas? I have a new dish that I need to try out.
Thanks for any help.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-08-2008, 07:51 PM
pgassler pgassler is offline
Junior Member
pgassler is on a distinguished road
Default
I had the same problem, and after about a month of troubleshooting, I finally found the problem. There is an overtemperature switch built into the electrical panel of the oven. Resetting this switch solved my problem.
To reset it:
TURN OFF THE POWER!
Open the door (if it is locked, turn the power back on and gently pull on the door every few seconds as the locking mechanism cycles until it is unlocked)
remove the 3 screws below the control panel (screws point upwards, with the head just inside the oven)
pull off the face of the control panel. Let it dangle by the wires so that you have access to the space behind it.
Within the electrical enclosure exposed by removing the control panel, Look for a small silver and black device with 2 wires attached to the back. The device is about .5" wide by 1" long and is attached with 2 screws to the sheet metal on the bottom of the electrical enclosure. Mine was located nearly in the middle of the electrical enclosure.
Push the tiny button on top of the switch. You should fee a click.
Reassemble and power up.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Slide-In Range F13 ERR jorgemed Oven Repair (including Ranges and Cooktops) 3 03-25-2008 10:05 AM
Roper slide in gas range oven problem dankodrum Oven Repair (including Ranges and Cooktops) 0 12-13-2007 12:01 PM
Kenmore 30" electric self-cleaning slide in range dennisjane Oven Repair (including Ranges and Cooktops) 0 11-21-2007 03:18 AM
Door latch broken/Door locked kitade Dishwasher Repair 2 10-23-2007 11:42 AM
Electric Double Oven - Lower Locked lfein Oven Repair (including Ranges and Cooktops) 0 09-21-2007 03:24 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
