I have a kenmore double oven built-in wall oven, model # 911.47722200. The top oven is not heating up. The top oven runs on digital display. All buttons seem to work and the display works. The bottom oven works on a dial & is working fine. I thought my top heating element had gone out so i switched it with the bottom oven element and it heated up. So, not the heating element. Also, the broil does not work in the top oven. I checked the wiring behind the display, it all seemed fine, no unconnected cords, burnt cords etc. No codes show up on the digital display, just the time or temp setting if i try to bake. I checked the thermal cut-out switch on the back of the top oven, it is ok. It is not getting power to that switch, so I checked the wiring from the oven control to thermal switch and it is ok. Is the only thing left is a bad oven control or is there something else to check?
