I have this Electric Range/Oven, that likes flashing the F1 or F0 code at weird times. It doesn't matter if your using it or walking past, or as I'm doing, renovating the kitchen, so there's pounding etc. According to the paper with the schematic drawing, the F1 code is a faulty control board, and must be replaced. Well over $200.00 later, and a new control board, which I installed myself, it keeps doing what it did, before installing the new board. I don't want to hear install another new board, but would like to get it working like it should, without it going off. Sometimes if I hit the cancel button once, it stops. Other times I have to press the darn button a dozen times or more, before it will finally stop, till the next time. Any insight on the problem with this, would be appreciated
