The Pilot Light Light And Will Light The Oven Burner. However, When The Oven Burner Turns Off The Pilot Right Goes Out. I Can Re-light It And The Next Time The Oven Lights It Will Light But Again When The Main Burner Goes Off The Pilot Light Also Is Out. The Pilot Light Is Very Low. There Are Two Screws On The Top Of The Control Under The Stove Top. Are These Controls And Which Is For The Pilot Light? Right Screw Or Left? Should I Clean The Pilot Light Jet With A Fine Wire Or Will This Damage It? Thanks For The Help Dwoody
