| » Oven doesn't always ignite |
Model Number: fgf366dcd Brand: Frigidaire Age: 1 - 5 years
As of late my oven has not been igniting. I set the temp and walk away only to return and its not working. I can get it to work after trying to turn it on and off several times in a row as well as slamming the door to attempt to "unstick" the valve(hoping that is the problem) It eventually lights after several attempts but I'm afraid I'm doing more damage if I continue to turn it on and off and slam the door.
Any clue what part it is I need to replace in order to get my oven back to "normal" working condition? Ads By Google Related Models |
If the oven (Bake) igniter does glow but there is no the gas flow, very likely the problem is a bad igniter. You can verify it by measuring the current drawn by the igniter.
If it is 3.2 amps or less, replace the igniter. If the reading is more than 3.2 amps, replace the gas safety valve. - The oven igniter Part number: AP3963540 - The gas safety valve Part number: AP3768099 Here are the breakdown diagrams and Burner replacement parts for FRIGIDAIRE FGF366DCD Frigidaire/range | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Without measuring the current it becomes kind of guessing because there are two questionable parts. In such situation I would replace the igniter first because it is more common and it cost much less.
__________________
| Display Modes | |
| maytag gas oven boiler and oven will not ignite | joe319 | Oven Repair (including Ranges and Cooktops) | 0 | 02-08-2010 06:49 AM |
| oven will not ignite | steve58 | Oven Repair (including Ranges and Cooktops) | 0 | 01-18-2010 05:49 PM |
| gas oven does not ignite | betty Eddy | Oven Repair (including Ranges and Cooktops) | 0 | 11-07-2009 06:32 AM |
| oven doesn't ignite | rhelber | Oven Repair (including Ranges and Cooktops) | 0 | 08-09-2009 01:11 PM |
| Oven Doesn't Ignite | Cochise | Oven Repair (including Ranges and Cooktops) | 1 | 09-10-2008 08:34 AM |
