Discuss
multimeter
 in
I am testing a sensor which is supposed to have a resistance of 1100 ohms. I switched to ohms,touched the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » multimeter
  #1 (permalink)
Old 07-29-2008, 02:54 PM
Junior Member
mainzy is on a distinguished road
Default multimeter
Brand: -brand-   Age: Less than 1 year
I am testing a sensor which is supposed to have a resistance of 1100 ohms. I switched to ohms,touched the probes together and zeroed my multimeter. then I inserted the probes into the sensor. The needle went one line above the 1.
This looks to me like 1.1ohms not 1100 would this be a correct assumption.
From right to left the numbers for ohms read 1,2,3,4,5,6,8,10,20,30,40,60,100,200,the last is1k and then the 8 on its side for infinity.
Thanks;Mainzy
Ads By Google
  #2 (permalink)
Old 07-30-2008, 08:01 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by mainzy View Post
...I switched to ohms,touched the probes together and zeroed my multimeter...
On the Ohm scale you can see Rx1, Rx10, Rx100 etc. In what position is the range knob on you meter?
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 07-30-2008, 09:50 PM
Junior Member
Default
The multimeter is a 19 dollar unit. There is only one place on it where you measure ohms. It is labeled ohm X1K.
  #4 (permalink)
Old 07-31-2008, 12:55 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Can you post a picture of this multimeter?
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Digital multimeter fluctuations Charles Burnette Dryer Repair 2 07-08-2009 07:20 AM
GE defrost timer operation (no multimeter) sgardner Refrigerator & Freezer Repair 1 05-15-2008 02:22 PM
