Discuss
Whirlpool Elect Double Oven no power
 in
Customer self cleaned top oven, no problem. When bottom oven was activated, all the power went out. This was last
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Whirlpool Elect Double Oven no power
  #1 (permalink)
Old 09-12-2007, 11:02 AM
lfein lfein is offline
Junior Member
lfein is on a distinguished road
Default Whirlpool Elect Double Oven no power
Model Number: GBD277PRS00   Brand: Whirlpool   Age: 1 - 5 years
Customer self cleaned top oven, no problem. When bottom oven was activated, all the power went out. This was last week. I shut off the breaker and waited 10 minutes hoping something would reset. No luck. This is built in and hardwired to 220. I just need to know how to access either the control (circuit) board or the latch or which screws to remove it from the cabinet, if necessary. Of course it is locked. Any help would be appreciated.
Thanks, Lenny in Austin
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-12-2007, 11:24 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Lenny
To get the access to the control board and the control compartment you have to unlatch the lower door. There is a solenoid on the door latch (behind the vent shield in the middle) which is blocking the latch hook from moving. Using a thin screwdriver, push the solenoid to release the hook.
After the door is open remove two screws from each side trims and pull the trim out from the bottom and then down to release it from the control panel tabs. Remove two screws on each side of the control panel and grabbing it on both sides from the bottom pull it toward yourself and up.
Now you have the access to the control compartment.
Good luck.
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
whirlpool oven does not work bob zaveri Oven Repair (including Ranges and Cooktops) 1 08-30-2007 08:43 PM
Whirlpool built in single oven doesn't heat DYLIAM Oven Repair (including Ranges and Cooktops) 1 08-15-2007 04:54 PM
Whirlpool oven won't light tpreston@dc.rr.com Oven Repair (including Ranges and Cooktops) 0 08-12-2007 01:10 PM
Whirlpool Oven Element Bad? kstidham Oven Repair (including Ranges and Cooktops) 1 08-02-2007 12:38 PM
Timer clock module for older Whirlpool oven webber123456 Oven Repair (including Ranges and Cooktops) 1 07-22-2007 11:16 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
