Discuss
Broiler Element Won't come on
 in
I have a Kenmore 629.45766 drop in range and the broiler element does not come on. I pulled the top
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Broiler Element Won't come on
  #1 (permalink)
Old 06-26-2010, 06:32 AM
Junior Member
wclifton1 is on a distinguished road
Default Broiler Element Won't come on
Model Number: 629.45766   Brand: Kenmore   Age: More than 10 years
I have a Kenmore 629.45766 drop in range and the broiler element does not come on. I pulled the top and checked the voltage to ground at the output pin on the relay card - 0. I get a reading on the bake and clock pins.
I don't see any other symptoms. The wiring harness do not look burnt. I tugged on each wire and they all seem made up. The connections all look tight.
To get to this point I have already replaced the clock (the original diagnosis by the Kenmore Service man), relay card and broiler element.
Ads By Google
Related Models
Kenmore 629.45766790  ELECTRIC RANGE
Maytag 629.45769 KENMORE COOKING
Kenmore 629.45769790  ELECTRIC RANGE
Kenmore 629.45775  KENMORE COOKING
Kenmore 629.45776  KENMORE COOKING
Kenmore 629.45779  KENMORE COOKING
Maytag 629.46775 KENMORE COOKING
Kenmore 629.46775690  ELECTRIC RANGE
Kenmore 629.46775790  ELECTRIC RANGE
Maytag 629.46776 KENMORE COOKING
Kenmore 629.46776790  ELECTRIC RANGE
Maytag 629.46779 KENMORE COOKING
Kenmore 629.46779790  ELECTRIC RANGE
Kenmore 629.46795  ELECTRIC RANGE
Kenmore 629.46796  ELECTRIC RANGE
Kenmore 629.46799  ELECTRIC RANGE
Jenn-Air 629.46965 Range - S/c S/i Ddraft Ele
Kenmore 629.46965  ELECTRIC RANGE
Jenn-Air 629.46969 Range - S/c S/i Ddraft Ele
Kenmore 629.46969  ELECTRIC RANGE
Kenmore 629.4697  ELECTRIC RANGE
Kenmore 629.46975  WIRING DIAGRAM-RANGE
Kenmore 629.46979  WIRING DIAGRAM-RANGE
Sears 629.69000  WHEEL KIT
Sears 629.69004  WHEEL KIT
Sears 629.69006  GASOLINE ENGINE KIT
Hardwick 629.70131 Range - F/s Std Gas
Kenmore 629.70131  GAS RANGE
Hardwick 629.70138 Range - F/s Std Gas
Kenmore 629.70138  GAS RANGE
Hardwick 629.70231 Range - F/s Std Gas
Kenmore 629.70231  GAS RANGE
Hardwick 629.70238 Range - F/s Std Gas
Kenmore 629.70238  GAS RANGE
Kenmore 629.756610  WALL FURNACE
Kenmore 629.756620  WALL FURNACE
Kenmore 629.756630  WALL FURNACE
Kenmore 629.756640  WALL FURNACE
Kenmore 629.756650  WALL FURNACE
Kenmore 629.756660  WALL FURNACE
Kenmore 629.756670  WALL FURNACE
Kenmore 629.756680  WALL FURNACE
Kenmore 629.756710  WALL FURNACE
Kenmore 629.756720  WALL FURNACE
Kenmore 629.756730  WALL FURNACE
Kenmore 629.756740  WALL FURNACE
Kenmore 629.756750  WALL FURNACE
Kenmore 629.756760  WALL FURNACE
Kenmore 629.756830  WALL FURNACE
Kenmore 629.756840  WALL FURNACE
Kenmore 629.756870  WALL FURNACE
Kenmore 629.756890  WALL FURNACE
Kenmore 629.756920  WALL FURNACE
Kenmore 629.756990  WALL FURNACE
Kenmore 629.776610  WALL FURNACE
Kenmore 629.776620  WALL FURNACE
Kenmore 629.776630  WALL FURNACE
Kenmore 629.776640  WALL FURNACE
Kenmore 629.776650  WALL FURNACE
Kenmore 629.776660  WALL FURNACE
Kenmore 629.776670  WALL FURNACE
Kenmore 629.776680  WALL FURNACE
Jenn-Air 629.80515 Misc / Accessory
Kenmore 629.80515  BACKSPLASH
Jenn-Air 629.80519 Misc / Accessory
Kenmore 629.80519  BACKSPLASH
Kenmore 629.90131  ELECTRIC RANGE
Kenmore 629.90138  ELECTRIC RANGE
Kenmore 629756810 GAS WALL FURNACE
Sears 629756811 SEARS TOP VENT GAS-FIRED WALL FURNACE
Kenmore 629756820 GAS WALL FURNACE
Sears 629756821 SEARS TOP VENT GAS-FIRED WALL FURNACE
Sears 629756831 SEARS DIRECT VENT GAS-FIRED WALL FURNACE
Sears 629756841 SEARS DIRECT VENT GAS-FIRED WALL FURNACE
Kenmore 629756850 GAS WALL FURNACE
Sears 629756851 SEARS TOP VENT GAS-FIRED WALL FURNACE
Kenmore 629756860 GAS WALL FURNACE
Sears 629756861 SEARS TOP VENT GAS-FIRED WALL FURNACE
Sears 629756871 SEARS DIRECT VENT GAS-FIRED WALL FURNACE
Kenmore 629756880 GAS WALL FURNACE
Sears 629756881 SEARS TOP VENT GAS-FIRED WALL FURNACE
Sears 629756891 SEARS DIRECT VENT GAS-FIRED WALL FURNACE
Kenmore 629756910 GAS WALL FURNACE
Sears 629756911 SEARS TOP VENT GAS-FIRED WALL FURNACE
Sears 629756921 SEARS DIRECT VENT GAS-FIRED WALL FURNACE
Kenmore 629776710 WALL FURNACE
Kenmore 629776720 WALL FURNACE
Kenmore 629776730 WALL FURNACE
Kenmore 629776740 WALL FURNACE
Kenmore 629776750 WALL FURNACE
Kenmore 629776760 WALL FURNACE
Kenmore 629776810 GAS WALL FURNACE
Sears 629776811 SEARS TOP VENT GAS-FIRED WALL FURNACE
Kenmore 629776820 GAS WALL FURNACE
Sears 629776821 SEARS TOP VENT GAS-FIRED WALL FURNACE
Kenmore 629776830 WALL FURNACE
Sears 629776831 SEARS DIRECT VENT GAS-FIRED WALL FURNACE
Kenmore 629776840 WALL FURNACE
Sears 629776841 SEARS DIRECT VENT GAS-FIRED WALL FURNACE
Kenmore 629776850 GAS WALL FURNACE
Sears 629776851 SEARS TOP VENT GAS-FIRED WALL FURNACE
Kenmore 629776860 GAS WALL FURNACE
Sears 629776861 SEARS TOP VENT GAS-FIRED WALL FURNACE
Kenmore 629776870 WALL FURNACE
Sears 629776871 SEARS DIRECT VENT GAS-FIRED WALL FURNACE
Kenmore 629776880 GAS WALL FURNACE
Sears 629776881 SEARS TOP VENT GAS-FIRED WALL FURNACE
Kenmore 629776890 WALL FURNACE
Sears 629776891 SEARS DIRECT VENT GAS-FIRED WALL FURNACE
Kenmore 629776910 GAS WALL FURNACE
Sears 629776911 SEARS TOP VENT GAS-FIRED WALL FURNACE
Kenmore 629776920 WALL FURNACE
Sears 629776921 SEARS DIRECT VENT GAS-FIRED WALL FURNACE
Magic Chef 62S14XAA Range - S/i Cont Clean Gas
Magic Chef 62S14XAS Range - S/i Cont Clean Gas
Magic Chef 62S14XAW Range - S/i Cont Clean Gas
Hoover 63 Frigidaire/electric Range
Amana 630.000 Mwave - Family Size (60 Hz)
Amana 630.001 Mwave - Family Size (60 Hz)
Amana 630.002 Range - S/c S/i Ddraft Gas
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
oven element/broiler element not working stove top is MD110772 Oven Repair (including Ranges and Cooktops) 3 07-05-2011 01:23 AM
broiler element won't go off creaker Oven Repair (including Ranges and Cooktops) 0 10-13-2009 10:04 AM
Broiler Element vs. Bake Element sblank3 Oven Repair (including Ranges and Cooktops) 6 02-18-2009 07:16 AM
Broiler element jaethri Oven Repair (including Ranges and Cooktops) 1 07-10-2008 08:35 PM
Broiler Element david323 Oven Repair (including Ranges and Cooktops) 1 11-23-2007 11:30 AM
