Register | FAQ's | New Posts | Today's Posts | Extras |
» propane gas oven doesn't light. |
![]() Model Number: JGBS23WEA2WW Brand: GE Age: 1 - 5 years
![]() It is a GE XL 44 gasrange(propane) Model JGBS23WEA2WW SERIAL#TZ143674P Issue? Basically when we turn the oven on it should only take up to 90 sec for the burner to go on, however it takes much longer(up to 20 min or sometimes does not come on at all. If I turn on the oven and look underneath where the burner is I can see something that glows and I assume that has to get hot enough so that it will ignite the burner and that seems to take forever or not at all. Hopefully this helps you with trying to figure out what the problem is. Thank you Related Models |
See inside of your appliance - diagrams and part photos for virtually every model.![]() powered by AppliancePartsPros.com |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
BUCK Propane fireplace pilot light | ncord51 | Heating, Ventilation, and Air Conditioning (HVAC) | 3 | 11-16-2009 07:25 AM |
rv norcold won't light W/ propane | highsierra | Refrigerator & Freezer Repair | 0 | 09-13-2009 04:33 PM |
Propane pilot light problem | jcapaci | General Talk | 8 | 01-22-2009 06:12 PM |
magic chef propane oven won't light (has pilot light) | A and J | Oven Repair (including Ranges and Cooktops) | 3 | 09-19-2008 12:36 PM |
