I am installing the display control board on a Thermador X301XP oven, and somewhow inadvertantly damaged one of the pin headers on the circuit board at the back of the touch panel display, that connects the control board to the display, with one of the cables. I have removed the part myself, and attaching pictures of the particular part I need to replace. Identifying connectors is quite a tough task . Can anyone identify the switch part, even better tell me where I can source the exact 2 pin header connector. Thanks, Mike Willerm attached the following image(s):
