The oven element stays on continuously. Unplugged it twice, didn't fix it. No error codes displayed at all. Turning oven on at 170 for 1 min, controlls appeared to work fine, but again on, with no errors indicated. Twice the oven temp got up to 650+/- deg. Finally unplugged one of the electrical lines at the control unit behind the digital readout, and everything else works, but the bottom oven heating element stays off.
Please help.
Thank you.
Most likely the problem is a bad control board (microcomputer). - The control board Part number: AP3174668
