| » Replacing the ignitor harness for GE cooktop |
Model Number: JGP970BEKBB Brand: GE Age: 1 - 5 years
Need help in replacing the ignitor harness switch (P/N WB18T10367) for a GE cooktop JGP970BEKBB. I see that this part is available online; but want to be sure that I can replace it before ordering
The cooktop has a glass surface which seems to be stuck to the counter with sticky foam. Can I remove the top burners and pry the glass surface up to reach the insides? Or do I need to go from the bottom and disconnect the gas line (not sure if I want to mess with the gas lines!!) Would appreciate some detailed step by step instructions. Thank you for your time. -Vish Ads By Google Related Models Last edited by ivin : 06-22-2010 at 08:54 AM. |
Quote:
I am stumped with the white ceramic electrodes sitting near the burners. How do I take them off? Thanks for your help. -Vish |
Please se my post
Why don't you ever give instructions for cracked cooktop replacement After I figured it out I went back and added instructions |
Quote:
Appreciate you sharing this knowledge. -Vish. |
Vish
Mine lifted right off after I removed the burners ! I would not pry on the glass as it is britle ! If yours is stuck down with sealant I would cut this with a razor knife but you might just be looking at the gasket that is under the glass ! You might also be able to lift up the whole unit and set it angled accross the openning ( without unhooking the gas ) so you can better see what your doing. Let Me know if you have more questions John |
| Display Modes | |
| Replacing Heater Harness | dlford | Refrigerator & Freezer Repair | 1 | 01-19-2010 04:28 AM |
| Replacing ignitor | buffalova | Oven Repair (including Ranges and Cooktops) | 0 | 06-23-2009 06:40 AM |
| ge cooktop ignitor | lou144160 | Oven Repair (including Ranges and Cooktops) | 1 | 11-16-2008 08:25 PM |
| GE Cooktop - Ignitor | nguyent | Oven Repair (including Ranges and Cooktops) | 1 | 09-23-2008 03:13 PM |
| Whirlpool cooktop harness replacement | midge | Oven Repair (including Ranges and Cooktops) | 0 | 02-25-2008 10:43 AM |
