Last night turned oven to 350 to cook and 15 min later came to check steak to find oven never lit. I see the igniter is golwing orange, possible igniter bad and will not allow gas flow? 8114p471-60 is the only # i can find on unit. Thank You for any advice as you helped me with dryer a yr ago and sure you can set me in right direction Artie
Replaced igniter which is very easy to do in 15 min. Oven working Artie
