| » Oven burner will not ignite |
Model Number: 31EN-3KLX Brand: Magic Chef Age: More than 10 years
The oven will not ignite, the top burners will ignite. The igniter glows a bright orange but no ignition. The igniter is rectangular ceramic type, and the bracket appears to be fastened with sheet metal screws to the burner and the back of the oven.
I suspect the igniter, please give me your professional advise. Can it be replace without having to come through the back of the oven, i.e. remove the sheet metal screws, disconnect the pwer source and replace? Thanks for your help. Related Models |
Yep, you can replace without removing the range, you need to remove the drawer to get to the electrical connections. Take a resistance reading of the glowbar, this will tell you if it is bad or not, you should get a reading of 50-150ohms, if not replace the glowbar.
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!! Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up. |
| Display Modes | |
| Burner will not ignite | Joyce Todd | Dryer Repair | 0 | 07-20-2008 09:01 PM |
| Bake burner won't ignite | untamedspirit | Oven Repair (including Ranges and Cooktops) | 10 | 06-18-2008 05:36 PM |
| Burner wont ignite | cocm | Oven Repair (including Ranges and Cooktops) | 5 | 02-23-2008 07:41 PM |
| Oven Pilot lit, but burner will not ignite | lsilvestri46 | Oven Repair (including Ranges and Cooktops) | 0 | 02-08-2008 04:09 PM |
| Burner won't ignite | flaumbetty | Oven Repair (including Ranges and Cooktops) | 5 | 01-25-2008 06:39 AM |
