Several months ago the oven light switch would turn the light on but would not shut off the light. After a time the light would go out by itself. Some time later the light started to turn on by itself, stay on for 15 to 30 minutes, and then turn off. It then stoped operating completely (both light bulbs are good). The light still does not work, but yesterday the light switch began buzzing. The only way to stop the buzzing is to hold your finger on the membrane light switch. I am assuning at this point that the solution is to replace the membrane containing the light switch. I pulled the control panel and membrane switch and found a part number 62682B REV.1 which you have in stock. Is it reasonable to assume this is the problem rather than a relay on the board? Since the replacement membrane is $154.27 I don't want to do a lot of trail and error. I would greatly appreciate your advice. Thank you.
