Clock was broken on my Frigidaire electric range/stove, so I ordered the replacement part 318012912. all connections matched up perfectly except the pin connector. The original has a 7 pin connector the new replacement part has 9 pins. I've ordered the correct part. what are my options? is there a converter that I can get or does someone know of another part number that will work
