| » Whirlpool Codes? Do not seem to be error codes |
Model Number: GR673LXSS Brand: Whirlpool Age: 1 - 5 years
We had an electrical surge at the home and now the range is not working correctly.
I see nothing on the control panel, but if i rotate one of the burner knobs to on i get these "codes" AM71 UI45 EEWE T204 I can set the clock and oven lights come on (but again i have to rotate the burner knob). No heat coming from any burners or oven. Can you explain the numbers that are showing on control panel? Thanks, tara Ads By Google Related Models |
I am posting for information only. The problem with my whirlpool was not an range problem it was insufficient power.
i decided to post here as most answer posts involve purchasing parts, or they are not answered. If you throw these codes, check your electrical supply. Whirlpool was not helpful when i called. They seemed to have no record of these codes. But the woman on the phone let me know they do not share info with callers but they should have a service call. My problem was i did not know which to call appliance or electric service. |
I am experiencing the same issue, I called Whirlpool they told me it was not an error code but a rebooting code and I needed a service call. Of course I told him I did not want to put out $160 if it could be electrical, just then I saw your issue, so needless to say I did not schedule a service call. But would like to know how you resolved it. Breaker or 220 cord?
What i wanted to know from them was do i need a service for appliance repair or electrical repair.
i did not post my exact fix because it was unique. i live in a vintage home that still has the long post fuses. i had pulled them out for another problem and when i reinserted them i had bent a prong and was not getting full power. i was getting 110 from the good side of the fuse holder and the bent side was not delivering any power. So i was showing some function (lights and clock). Never threw a error code that had an E or F associated with it. A friend came over with a voltage meter and tracked it down. Whirpool knew well and good what those codes were, it was not just a random set of numbers, as evidenced by you having them also. Check electical not your range. |
Quote:
Thanks again and good luck with your range. Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
| Display Modes | |
| error codes on whirlpool duet sport | Thad Steele | Washer Repair | 4 | 05-09-2011 09:01 PM |
| Whirlpool gas range error codes | Dan Wilshire | Oven Repair (including Ranges and Cooktops) | 1 | 07-08-2009 10:31 AM |
| Whirlpool Double Oven Error Codes | alaucks | Oven Repair (including Ranges and Cooktops) | 2 | 01-15-2009 09:31 PM |
| Error Codes Whirlpool Oven | brummel | Oven Repair (including Ranges and Cooktops) | 0 | 08-25-2008 12:27 PM |
| Whirlpool Gold Error Codes | YPKenny412 | Oven Repair (including Ranges and Cooktops) | 0 | 06-30-2008 02:04 PM |
