| » Jenn-air 88370 Schematics |
Model Number: 88370C Brand: Jenn-Air Age: More than 10 years
Hi, I am looking for wiring diagrams or schematics for a Jenn-air model 88370 which is +20 years old.
I am experiencing problems with the oven, both top and bottom elements get hot---but the food is frequently cooked unevenly. Also the temperature of my cartridge elements is difficult to adjust with the control, it is only warm or too hot.......I am not sure if it is the control or the element, since both elements of the same cartridge acts the same. A schematics would help me troubleshoot .... regards Great forum ! Ads By Google Related Models |
Hi Claude,
I couldn't find the wiring diagram for this model. There should be one inside the unit though. Both oven elements should be bright red all around. Check it out. Set the oven to BAKE (350 degrees), give it a couple of minutes, then look at the bake element. If the element coil is not consistently red all the way around and has dark spots on it, the element is too weak and needs to be replaced. If the element looks to be ok, then check your oven temperature using an oven thermometer. As far as the top elements... Since you're saying that both elements do get hot, the problem is most likely with the switches. I know, it is unlikely for both switches to go out at the same time, but this is an older oven and maybe one of the switches started going sometime before the other did. If one of the elements weren't getting red hot, then I'd tell you to check both the element and its receptacle, but that's not the case here. Hope this helps. |
Hi
I've attached two schematics for Jennair Electric stoves. One is for an 88370, which has a little bit of it missing, but you can still tell it is the white line for ground/common. The other schematic, which is complete and shows the white line. It is for an 88368. The schematics appear to be identical except the 88368 doesn't have a clock, and those connections are just wire nutted. Your posting is about 5 months old, so I may be very late is sending this info. I just today joined the forum. Witchman1034 |
| Display Modes | |
| Jenn Air 88370 clock noise driving us crazy | tgirwf | Oven Repair (including Ranges and Cooktops) | 1 | 12-31-2010 08:44 AM |
| Old Jenn-air oven/cooktop (88370) won't heat unless... | frenchtown_flyer | Oven Repair (including Ranges and Cooktops) | 0 | 11-04-2009 07:20 AM |
| wiring schematics | tina duncan | Dishwasher Repair | 5 | 12-13-2008 08:23 PM |
| Jenn Air 88370 Burner problems | gizmo1 | Oven Repair (including Ranges and Cooktops) | 1 | 09-24-2008 02:56 PM |
