Discuss
F3 Error code on whirlpool Range
 in
Keep getting this F3 error code then none of the oven controls will work. The other day I unplugged it
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » F3 Error code on whirlpool Range
  #1 (permalink)
Old 09-10-2007, 06:36 PM
Larry56 Larry56 is offline
Junior Member
Larry56 is on a distinguished road
Default F3 Error code on whirlpool Range
Model Number: RF396PXYQ3   Brand: Whirlpool   Age: 5 - 10 years
Keep getting this F3 error code then none of the oven controls will work. The other day I unplugged it then I was able to bake, when I turned it off it started to beep and go to the code and lock up again. So far have not been able to get it back on. Does anyone know what the code is telling me to replace? The book says to call service.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-10-2007, 07:06 PM
Admin / APP Team Admin / APP Team is offline
Administrator
APP Team
Admin / APP Team has disabled reputation
Default
F3 stands for a faulty oven sensor. Unplug the oven, then replace the sensor. Should be back to normal. The sensor is inside the oven. When you pull on the sensor, you'll get to a male/female quick connector. When you unplug it, be careful not to lose the other end behind the oven wall or this simple repair won't be so simple anymore.
- Replacement sensor for your oven
Let us know how it goes.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
F3 error code mich26 Microwave Repair 3 01-23-2008 07:28 PM
Duet Sport F01 error Code vposton Washer Repair 2 09-15-2007 08:20 AM
F 1 Error Code Frogburk Oven Repair (including Ranges and Cooktops) 1 08-29-2007 03:10 PM
e-10 error code hoogabooga Washer Repair 0 08-28-2007 03:57 PM
F2 - Error Code Wilson Oven Repair (including Ranges and Cooktops) 3 08-23-2007 10:49 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
