All 4 of my burners will light, but just as they seem to warm up...they go out. If I wait, they will relight again....just to go out in a minute or two. The range was recently opened up for an F1 error code. We are awaitiing the new ERC. The problem with the burners did not begin until a week or so after the range was put back together. We were just shutting it off at the breaker to avoid the beeping in the middle of the night. Yes, the range is switched back on at the breaker when the gas problem is happening. Thanks in advance for your help.
