Discuss
Oven temp problem
 in
I have several questions regarding this unit. The first one is, are all of the four topside burners using the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven temp problem
  #1 (permalink)
Old 06-08-2010, 09:47 PM
Junior Member
usmcmaddog is on a distinguished road
Default Oven temp problem
Model Number: ARGS7650WW   Brand: Amana   Age: 5 - 10 years
I have several questions regarding this unit. The first one is, are all of the four topside burners using the same ignitor/Part Number? The second, is the High Surface Ignitor for the Bake cycle the Bake ignitor? I have a problem which seams to be common for this unit, in that you can program the bake temp into the contol panel but nothing happens afterwards. My first thought was that it might be the thermocouple, but if there is no proof of flame, it could be the ignitor, and or valve, but since gas valves are less likely to fail statisticly, my thoughts came back around to the ignitor for the bake cycle. The broil cycle works only on the high setting, so I do not have the control schematics to know if the two are interconnected, or just coincidentally related...any help would be appreciated, thanks in advance....
Ads By Google
Related Models
Amana ARGS7650WW RANGE- S/C S/I GAS
Amana ARH660 RANGE- S/C S/I DDRAFT GAS
Amana ARH660 RANGE- S/C S/I DDRAFT ELE
Amana ARH660HR RANGE- S/C S/I DDRAFT ELE
Amana ARH664E RANGE- S/C S/I DDRAFT ELE
Amana ARH664WW RANGE- S/C S/I DDRAFT ELE
Amana ARH665E RANGE- S/C S/I DDRAFT ELE
Amana ARH665WW RANGE- S/C S/I DDRAFT ELE
Amana ARH667E RANGE- S/C F/S ELE
Amana ARH667WW RANGE- S/C S/I DDRAFT ELE
Amana ARH6700E RANGE- S/C S/I DDRAFT GAS
Amana ARH6700E RANGE- S/C F/S ELE
Amana ARH6700LL RANGE- S/C S/I DDRAFT GAS
Amana ARH6700LL RANGE- S/C F/S ELE
Amana ARH6700WW RANGE- S/C S/I DDRAFT GAS
Amana ARH6710E RANGE- S/C S/I DDRAFT GAS
Amana ARH6710LL RANGE- S/C S/I DDRAFT GAS
Amana ARH6710WW RANGE- S/C S/I DDRAFT GAS
Amana ARHC7700E RANGE- S/C S/I DDRAFT ELE
Amana ARHC7700LL RANGE- S/C S/I DDRAFT ELE
Amana ARHC7700WW RANGE- S/C S/I DDRAFT ELE
Amana ARHC8700E RANGE- S/C F/S ELE
Amana ARHC8700LL RANGE- S/C F/S ELE
Amana ARHC8700WW RANGE- S/C F/S ELE
Amana ARHSC8750E RANGE- S/C S/I DDRAFT ELE
Amana ARHSC8750WW RANGE- S/C S/I DDRAFT ELE
General Electric ARK18D2V1 Room air conditioner
Amana ARO3100L RANGE- S/C S/I DDRAFT GAS
Amana ARO3100W RANGE- S/C S/I DDRAFT GAS
Amana ARO3400L RANGE- S/C S/I DDRAFT GAS
Amana ARO3400W RANGE- S/C S/I DDRAFT GAS
Amana ARR-201 RANGE- S/C S/I DDRAFT ELE
Amana ARR-201 RANGE- S/C S/I DDRAFT GAS
Amana ARR-401 RANGE- S/C S/I DDRAFT ELE
Amana ARR-401 RANGE- S/C S/I DDRAFT GAS
Amana ARR-402 RANGE- S/C S/I DDRAFT ELE
Amana ARR-402 RANGE- S/C S/I DDRAFT GAS
Amana ARR-405 RANGE- S/C S/I DDRAFT GAS
Amana ARR-405 RANGE- S/C S/I DDRAFT ELE
Amana ARR-412 RANGE- S/C S/I DDRAFT ELE
Amana ARR-415 RANGE- S/C S/I DDRAFT ELE
Amana ARR101W RANGE- S/C S/I DDRAFT ELE
Amana ARR301 RANGE- S/C S/I DDRAFT ELE
Amana ARR301W RANGE- S/C S/I DDRAFT ELE
Amana ARR303 RANGE- S/C S/I DDRAFT ELE
Amana ARR303W RANGE- S/C S/I DDRAFT ELE
Amana ARR305 RANGE- S/C S/I DDRAFT ELE
Amana ARR3100L RANGE- S/C S/I DDRAFT GAS
Amana ARR3100NL RANGE- S/C S/I DDRAFT GAS
Amana ARR3100NW RANGE- S/C S/I DDRAFT GAS
Amana ARR3100W RANGE- S/C S/I DDRAFT GAS
Amana ARR3400L RANGE- S/C S/I DDRAFT GAS
Amana ARR3400W RANGE- S/C S/I DDRAFT GAS
Amana ARR3601LL Range - S/c S/i Ddraft Gas
Amana ARR3601LL RANGE- S/C S/I DDRAFT GAS
Amana ARR3601WW Range - S/c S/i Ddraft Gas
Amana ARR3601WW RANGE- S/C S/I DDRAFT GAS
Amana ARR5200L RANGE- STD MWAVE ELE
Amana ARR5200W RANGE- STD MWAVE ELE
Amana ARR600 RANGE- S/C S/I DDRAFT GAS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
New gas oven temp problem Whim60 Oven Repair (including Ranges and Cooktops) 0 04-23-2009 07:54 PM
GE oven temp problem Mike Meining Oven Repair (including Ranges and Cooktops) 0 04-11-2009 03:58 PM
oven temp problem StNick55 Oven Repair (including Ranges and Cooktops) 1 12-02-2008 09:54 AM
oven temp problem StNick55 Oven Repair (including Ranges and Cooktops) 1 11-25-2008 12:14 PM
GE Spectra oven temp problem ace o spades Oven Repair (including Ranges and Cooktops) 1 01-28-2008 11:44 AM
