Discuss
Microwave it totally dead
 in
Microwave Repair
I have a Maytag over the range microwave that suddenly died last week. I've been trying to diagnose the problem,
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Microwave it totally dead
  #1 (permalink)
Old 06-06-2010, 11:40 AM
Junior Member
fatron is on a distinguished road
Default Microwave it totally dead
Model Number: MMV4205BAQ   Brand: Maytag   Age: 1 - 5 years
I have a Maytag over the range microwave that suddenly died last week. I've been trying to diagnose the problem, but haven't had any luck. Here's what I know.
The power outlet is good.
The 2 internal fuses are good.
All of the thermal cutoffs are reading properly according to the schematic in the mini-manual found behind the control panel.
The HV Capacitor doesn't seem to be charging, but I think that is due to the high power relay not closing because of the dead control panel.
The HV capacitor seems to read properly when I apply an ohmmeter.
The HV diode is good.
All 3 interlock switches are reading what they should when the door is open and closed.
The magnatron appears to be reading properly according to the test procedure in the mini manual (less than 1 ohm across terminals).
The HV transformer seems OK, but I'm not sure If I am testing it properly because the picture in the manual doesn't quite match the transformer in the microwave.
I'm getting voltage out of the filter circuit board where the fuses are located.
At this point, I think that either the control board isn't getting voltage, or that something has died on the main control board, I'm just not sure where to continue checking because I can't figure out which wires are suppose to supply voltage to the circuit board. I did find 2 capacitors on the PCB that are reading open, and am assuming they should read low resistance, then up to infinity, when I attach my multimeter, but am not sure how these particular capacitors should read. One capacitor is a disk type (sc472m) and the other is a larger film type (PCX2 335M MKP).
Any ideas on what might be wrong, or what to check next?
Thanks.
Related Models
Maytag MMV4205BAQ MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV4205BAQ14 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV4205BAQ17 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Maytag MMV4205BAS MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV4205BAS14 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV4205BAS17 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Maytag MMV4205BAW MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV4205BAW15 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV4205BAW18 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Maytag MMV5000ADA MWAVE- MOUNTED UNDER CABINET
Maytag MMV5000ADB MWAVE- MOUNTED UNDER CABINET
Maytag MMV5000ADW MWAVE- MOUNTED UNDER CABINET
Maytag MMV5000BAB MWAVE- MOUNTED UNDER CABINET
Maytag MMV5000BAC MWAVE- MOUNTED UNDER CABINET
Maytag MMV5000BAQ MWAVE- MOUNTED UNDER CABINET
Maytag MMV5000BAW MWAVE- MOUNTED UNDER CABINET
Maytag MMV5000BDB MWAVE- MOUNTED UNDER CABINET
Maytag MMV5000BDC MWAVE- MOUNTED UNDER CABINET
Maytag MMV5000BDQ MWAVE- MOUNTED UNDER CABINET
Maytag MMV5000BDW MWAVE- MOUNTED UNDER CABINET
Maytag MMV5100AAB MWAVE- MOUNTED UNDER CABINET
Maytag MMV5100AAQ MWAVE- MOUNTED UNDER CABINET
Maytag MMV5100AAS MWAVE- MOUNTED UNDER CABINET
Maytag MMV5100AAW MWAVE- MOUNTED UNDER CABINET
Maytag MMV5156AAB MWAVE- MOUNTED UNDER CABINET
Maytag MMV5156AAQ MWAVE- MOUNTED UNDER CABINET
Maytag MMV5156AAS MWAVE- MOUNTED UNDER CABINET
Maytag MMV5156AAW MWAVE- MOUNTED UNDER CABINET
Maytag MMV5156ACB MWAVE- MOUNTED UNDER CABINET
Maytag MMV5156ACQ MWAVE- MOUNTED UNDER CABINET
Maytag MMV5156ACS MWAVE- MOUNTED UNDER CABINET
Maytag MMV5156ACW MWAVE- MOUNTED UNDER CABINET
Maytag MMV5165AAB MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5165AAQ MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5165AAS MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5165AAW MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5165BAB MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5165BAB14 Microwave Oven/Hood 1.6 Cu. Ft.
Maytag MMV5165BAB15 MICROWAVE OVEN/HOOD 1.6 Cu. Ft.
Maytag MMV5165BAS MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5165BAS14 Microwave Oven/Hood 1.6 Cu. Ft.
Maytag MMV5165BAS15 MICROWAVE OVEN/HOOD 1.6 Cu. Ft.
Maytag MMV5165BAW MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5165BAW15 Microwave Oven/Hood 1.6 Cu. Ft.
Maytag MMV5165BAW16 MICROWAVE OVEN/HOOD 1.6 Cu. Ft.
Maytag MMV5186AAB MWAVE- MOUNTED UNDER CABINET
Maytag MMV5186AAQ MWAVE- MOUNTED UNDER CABINET
Maytag MMV5186AAS MWAVE- MOUNTED UNDER CABINET
Maytag MMV5186AAW MWAVE- MOUNTED UNDER CABINET
Maytag MMV5186ACB MWAVE- MOUNTED UNDER CABINET
Maytag MMV5186ACQ MWAVE- MOUNTED UNDER CABINET
Maytag MMV5186ACS MWAVE- MOUNTED UNDER CABINET
Maytag MMV5186ACW MWAVE- MOUNTED UNDER CABINET
Maytag MMV5201DB00 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV5201DS00 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV5201DW00 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV5207AAB MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207AAQ MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207AAS MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207AAW MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207ACB MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207ACQ MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207ACS MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207ACW MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207BAB MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207BAB14 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BAB17 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV5207BAQ MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207BAQ14 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BAQ17 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV5207BAS MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207BAS14 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BAS17 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV5207BAW MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207BAW15 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BAW18 MICROWAVE OVEN/HOOD 2.0 Cu. Ft.
Maytag MMV5207BCB MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207BCB14 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCB17 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCB18 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCQ MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207BCQ14 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCQ17 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCQ18 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCS MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207BCS14 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCS17 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCS18 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCW MWAVE- MOUNTED OVER RANGE/WO
Maytag MMV5207BCW15 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCW18 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5207BCW19 Microwave Oven/Hood 2.0 Cu. Ft.
Maytag MMV5208WB0 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Maytag MMV5208WQ0 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Maytag MMV5208WS0 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Maytag MMV5208WW0 MICROWAVE OVEN/HOOD 2.0 CU. FT.
Maytag MMV6178AAB MICROWAVE - CONVECTION
Maytag MMV6178AAQ MICROWAVE - CONVECTION
Maytag MMV6178AAS MICROWAVE - CONVECTION
Maytag MMV6178AAW MICROWAVE - CONVECTION
Maytag MMV6180WB0 Microwave Oven/Hood 1.8 Cu. Ft.
Maytag MMV6180WS0 Microwave Oven/Hood 1.8 Cu. Ft.
Maytag MMV6180WW0 Microwave Oven/Hood 1.8 Cu. Ft.
Maytag MMV6186WB0 Microwave Oven/Hood 1.8 Cu. Ft.
Maytag MMV6186WS0 Microwave Oven/Hood 1.8 Cu. Ft.
Maytag MMV6186WW0 Microwave Oven/Hood 1.8 Cu. Ft.
Maytag MMW5527BAB WALLOVEN- S/C ELE
Maytag MMW5527BAW WALLOVEN- S/C ELE
Maytag MMW5527CAB WALLOVEN- S/C ELE
Maytag MMW5527CAW WALLOVEN- S/C ELE
Maytag MMW5530BAB WALLOVEN- S/C ELE
Maytag MMW5530BAW WALLOVEN- S/C ELE
Maytag MMW5530CAB WALLOVEN- S/C ELE
Maytag MMW5530CAW WALLOVEN- S/C ELE
Maytag MMW5530DAB WALLOVEN- S/C MWAVE ELE
Maytag MMW5530DAB20 30" BUILT-IN MICROWAVE/ELECTRIC OVEN COMBO SELF-CLEAN
Maytag MMW5530DAW WALLOVEN- S/C MWAVE ELE
Maytag MMW5530DAW21 30" BUILT-IN MICROWAVE/ELECTRIC OVEN COMBO SELF-CLEAN
Maytag MMW7530WDB01 30" BUILT-IN ELECTRIC COMBO SENSOR/SC
Maytag MMW7530WDS01 30" BUILT-IN ELECTRIC COMBO SENSOR/SC
  #2 (permalink)
Old 09-03-2010, 05:29 AM
Junior Member
jhelmick is on a distinguished road
Default
Exact same problem I had. Check the terminal connections at the cabinet overload, mine melted. With this being an open circuit NOTHING would work, no display, no light. It it located by the light in the top of cabinet, access by removing outer skin of cabinet and under metal cover.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool dishwasher totally dead MarkinATL Dishwasher Repair 11 12-21-2011 03:09 AM
Hotpoint range #RB526C3WW Totally Dead JOSEPH RUBANO Oven Repair (including Ranges and Cooktops) 2 04-21-2010 05:23 PM
dead microwave les1 Microwave Repair 0 08-02-2009 07:43 PM
Microwave totally "dead" whiztech Microwave Repair 5 04-25-2009 10:38 PM
dead microwave kenbs Microwave Repair 5 02-15-2009 03:01 PM
