torsion spring / bulb
Model Number: KEMS308GSS1 Brand: Kitchen Aid Age: 5 - 10 years
Torsion Spring -
This is the forth time I have had to replace this spring. I have read your comments to others in reference to this problem. I am glad you got some response from Kitchen Aid, for I have gotten none, after numerous phone calls(even speaking with supervisors) and letters to them. I can not believe that they will not do anything about this problem! My question then, is that I want to order the correct spring, actually two of them, one as a back up. Your responses to others show an RH and a LH, should I get just the RH? Is this the heavier spring?
Light Bulb -
The bulb has blown out for the second time in this unit. Can you give me a break down of how to change this, I also want to change the glass cover for it is discolored. I think the unit has to come out? I did not do this repair the last time, so any suggestions would be greatly appreciated.
Thanks, RB
