Discuss
Does Not Heat
 in
Microwave Repair
Everything else appears to work, the clock, timer, light, display. It simply will not heat anything up. I need help.
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Does Not Heat
  #1 (permalink)
Old 07-07-2008, 05:02 PM
Tunaman Tunaman is offline
Junior Member
Tunaman is on a distinguished road
Default Does Not Heat
Model Number: JMV8196AAQ   Brand: Jenn-Air   Age: 1 - 5 years
I need help.
Related Models
Jenn-Air JMV8196AAQ Mwave - Mounted Under Cabinet
Jenn-Air JMV8196AAS Mwave - Mounted Under Cabinet
Jenn-Air JMV8196AAW Mwave - Mounted Under Cabinet
Jenn-Air JMV8196ACB Mwave - Mounted Under Cabinet
Jenn-Air JMV8196ACQ Mwave - Mounted Under Cabinet
Jenn-Air JMV8196ACS Mwave - Mounted Under Cabinet
Jenn-Air JMV8196ACW Mwave - Mounted Under Cabinet
Jenn-Air JMV8208AAB Mwave - Mounted Over Range/wo
Jenn-Air JMV8208AAQ Mwave - Mounted Over Range/wo
Jenn-Air JMV8208AAS Mwave - Mounted Over Range/wo
Jenn-Air JMV8208AAW Mwave - Mounted Over Range/wo
Jenn-Air JMV8208ACB Mwave - Mounted Over Range/wo
Jenn-Air JMV8208ACS Mwave - Mounted Over Range/wo
Jenn-Air JMV8208ACW Mwave - Mounted Over Range/wo
Jenn-Air JMV8208BAB Mwave - Mounted Over Range/wo
Jenn-Air JMV8208BAS Mwave - Mounted Over Range/wo
Jenn-Air JMV8208BAW Mwave - Mounted Over Range/wo
Jenn-Air JMV8208BCB Mwave - Mounted Over Range/wo
Jenn-Air JMV8208BCQ Mwave - Mounted Over Range/wo
Jenn-Air JMV8208BCS Mwave - Mounted Over Range/wo
Jenn-Air JMV8208BCW Mwave - Mounted Over Range/wo
Jenn-Air JMV9169BAB Beaumark/washer
Jenn-Air JMV9169BAP Mwave - Mounted Over Range/wo
Jenn-Air JMV9169BAS Mwave - Mounted Over Range/wo
Jenn-Air JMV9169BAW Mwave - Mounted Over Range/wo
Jenn-Air JMW8130AAB Walloven - S/c Mwave Ele
Jenn-Air JMW8130AAW Walloven - S/c Mwave Ele
Jenn-Air JMW8130DAB Walloven - S/c Mwave Ele
Jenn-Air JMW8130DAS Walloven - S/c Mwave Ele
Jenn-Air JMW8130DAW Walloven - S/c Mwave Ele
Jenn-Air JMW8330DAB Walloven - S/c Mwave Ele
Jenn-Air JMW8330DAS Walloven - S/c Mwave Ele
Jenn-Air JMW8330DAW Walloven - S/c Mwave Ele
Jenn-Air JMW8527AAB Walloven - S/c Mwave Ele
Jenn-Air JMW8527AAW Walloven - S/c Mwave Ele
Jenn-Air JMW8527BAB Walloven - S/c Mwave Ele
Jenn-Air JMW8527BAW Walloven - S/c Mwave Ele
Jenn-Air JMW8527CAB Walloven - S/c Mwave Ele
Jenn-Air JMW8527CAS Walloven - S/c Mwave Ele
Jenn-Air JMW8527CAW Walloven - S/c Mwave Ele
Jenn-Air JMW8527DAB Walloven - S/c Mwave Ele
Jenn-Air JMW8527DAQ Walloven - S/c Mwave Ele
Jenn-Air JMW8527DAS Walloven - S/c Mwave Ele
Jenn-Air JMW8527DAW Walloven - S/c Mwave Ele
Jenn-Air JMW8530AAB Walloven - S/c Mwave Ele
Jenn-Air JMW8530AAW Walloven - S/c Mwave Ele
Jenn-Air JMW8530BAB Walloven - S/c Mwave Ele
Jenn-Air JMW8530BAW Walloven - S/c Mwave Ele
Jenn-Air JMW8530CAB Walloven - S/c Mwave Ele
Jenn-Air JMW8530CAS Walloven - S/c Mwave Ele
Jenn-Air JMW8530CAW Walloven - S/c Mwave Ele
Jenn-Air JMW8530DAB Walloven - S/c Mwave Ele
Jenn-Air JMW8530DAQ Walloven - S/c Mwave Ele
Jenn-Air JMW8530DAS Walloven - S/c Mwave Ele
Jenn-Air JMW8530DAW Walloven - S/c Mwave Ele
Jenn-Air JMW9130DAB Walloven - Std Mwave Ele
Jenn-Air JMW9130DAS Walloven - Std Mwave Ele
Jenn-Air JMW9130DAW Walloven - Std Mwave Ele
Jenn-Air JMW9330DAB Walloven - S/c Mwave Ele
Jenn-Air JMW9330DAS Walloven - S/c Mwave Ele
Jenn-Air JMW9330DAW Walloven - S/c Mwave Ele
Jenn-Air JMW9527AAB Walloven - S/c Mwave Ele
Jenn-Air JMW9527AAQ Walloven - S/c Mwave Ele
Jenn-Air JMW9527AAW Walloven - S/c Mwave Ele
Jenn-Air JMW9527BAB Walloven - S/c Mwave Ele
Jenn-Air JMW9527BAQ Walloven - S/c Mwave Ele
Jenn-Air JMW9527BAW Walloven - S/c Mwave Ele
Jenn-Air JMW9527CAB Walloven - S/c Mwave Ele
Jenn-Air JMW9527CAQ Walloven - S/c Mwave Ele
Jenn-Air JMW9527CAS Walloven - S/c Mwave Ele
Jenn-Air JMW9527CAW Walloven - S/c Mwave Ele
Jenn-Air JMW9527DAB Walloven - S/c Mwave Ele
Jenn-Air JMW9527DAS Walloven - S/c Mwave Ele
Jenn-Air JMW9527DAW Walloven - S/c Mwave Ele
Jenn-Air JMW9530AAB Walloven - S/c Mwave Ele
Jenn-Air JMW9530AAQ Walloven - S/c Mwave Ele
Jenn-Air JMW9530AAW Walloven - S/c Mwave Ele
Jenn-Air JMW9530BAB Walloven - S/c Mwave Ele
Jenn-Air JMW9530BAQ Walloven - S/c Mwave Ele
Jenn-Air JMW9530BAW Walloven - S/c Mwave Ele
Jenn-Air JMW9530CAB Walloven - S/c Mwave Ele
Jenn-Air JMW9530CAQ Walloven - S/c Mwave Ele
Jenn-Air JMW9530CAS Walloven - S/c Mwave Ele
Jenn-Air JMW9530CAW Walloven - S/c Mwave Ele
Jenn-Air JMW9530DAB Walloven - S/c Mwave Ele
Jenn-Air JMW9530DAS Walloven - S/c Mwave Ele
Jenn-Air JMW9530DAW Walloven - S/c Mwave Ele
General Electric JN30*01 Electric range
General Electric JN30*02 Electric range
General Electric JN319WIW Electric range
General Electric JN322*01 Electric range
General Electric JN322*02 Electric range
General Electric JN322*03 Electric range
General Electric JN322*J1 Electric range
General Electric JN322*J2 Electric range
General Electric JN322J3 Electric range
General Electric JN322S2 Gas range
General Electric JN322S3AD Range accessory
General Electric JN322S3WH Range accessory
General Electric JN322V1AD Range accessory
General Electric JN322V1WH Range accessory
General Electric JN327H1AA Electric range
General Electric JN327H1BB Electric range
General Electric JN327H1CC Electric range
General Electric JN327H1WW Electric range
General Electric JN327X1AD Range accessory
General Electric JN327X1CT Range accessory
General Electric JN327X1WH Range accessory
General Electric JN330*01 Electric range
General Electric JN330*02 Electric range
General Electric JN330*03 Electric range
General Electric JN334*01 Electric range
General Electric JN334*02 Electric range
General Electric JN334*03 Electric range
General Electric JN334*J1 Electric range
General Electric JN334*J2 Electric range
General Electric JN334J3 Electric range
General Electric JN334R1 Electric range
General Electric JN334S1 Gas range
General Electric JN335R1 Electric range
  #2 (permalink)
Old 07-08-2008, 03:20 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Does it make any unusual noise?
__________________
  #3 (permalink)
Old 07-08-2008, 03:27 PM
Junior Member
Default
No strange noises at all. Like normal, once the time is set and you press the start button, the carousel works, the light is on and the timer is working.
In the past and on another m-oven, I replaced a large fuse and I was good to go. However, with this oven, I see no access to such possibility.
08 Jul 08
  #4 (permalink)
Old 07-08-2008, 03:34 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Most likely the problem is a bad magnetron. In order to replace it the microwave has to be removed from the cabinet.
- The part number for the magnetron is AP4315294
__________________
  #5 (permalink)
Old 07-08-2008, 03:48 PM
Junior Member
Post
Is this a hard fix? Is it a relatively simple repair?
I am assuming I will have to remove the m-oven from the kitchen cabinets.
  #6 (permalink)
Old 07-08-2008, 06:05 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Yes, the microwave has to be removed and taken apart.
__________________
  #7 (permalink)
Old 07-09-2008, 09:44 AM
Junior Member
Default
Thank you. I took a quick look at the installation. It appears as though it mounts by some means from the top. I'll keep you posted. By the way, is the magnatron high dollar to the extent that maybe I should consider buying a whole new oven? This one was here when we moved in.
I appreciate your input and suggestions. Thanks again.
  #8 (permalink)
Old 07-09-2008, 02:16 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Your decision to fix or replace the microwave should be based on the condition and age of the existing and cost of repair vs price for a new.
__________________
  #9 (permalink)
Old 07-22-2008, 11:07 AM
Junior Member
Default
I removed the exterior cover of the oven and could see nothing visibly wrong. With the cover off, I carefully and briefly powered up the unit and again, everything appears to work fine. I am assuming that the magnatron is the one component located just above the transformer with a cooling fan blowing on it. I also noted a large capacitor in the vacinity. Once the AC power is disconnected, i.e. the power cord, are there any precautions I should be aware of during dissassembly?
  #10 (permalink)
Old 07-23-2008, 12:14 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The first and very important thing is to discharge the capacitor.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer will not heat during timed drying; will heat for short time while auto drying mg13nj Dryer Repair 11 11-11-2008 04:50 PM
Heat but not drying, seems like heat is not blowing good Papa1 Dryer Repair 2 10-07-2007 11:11 AM
