| » GE microwave wont heat - help!!! |
Model Number: jvm1870sf001 Brand: GE Age: 1 - 5 years
my ge profile over the range microwave wont heat, everything works and sound fine but no heat. i took it down and the cover off, i waited 24 hrs and then checked the high voltage capacitor to make sure it was not charged, then checked the fuse which had continuity and then checked the door switches.
when i take the switches out they all (3) worked fine, meaning they all registered 0 and then infinity when you push in the button. but when i hook the wires up to them the bottom 2 give me 0 with the door open or closed and the top one is 0 when the door is closed but when i open the door the switch slowly goes to about 20 ohms? this switch has 2 orange wires which are connected to the smart board. this doesnt seem right. anyone know what would cause this? a bad smart board maybe? thanks for your help dan |
Your door switches are fine. Sounds like your magnetron tube has failed. When you press start, you should here a click from the relay on the control panel. If you hear the relay click you need a new magtube and diode. If there is no click, then it could be the control board. The relay on the board that send power to the mag is the tall relay with 2 wires attached.
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!! Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up. |
| Display Modes | |
| Timer wont advance and dryer wont heat | awatt26 | Dryer Repair | 2 | 06-20-2008 10:43 PM |
| Sharp microwave wont work, all else does?? | janarmour | Microwave Repair | 0 | 05-24-2008 10:51 AM |
| Microwave wont heat the stuff | DC42 | Microwave Repair | 7 | 04-10-2008 04:29 PM |
| Microwave Wont Heat | RufusB | Microwave Repair | 0 | 11-08-2007 04:18 PM |
| microwave wont heat | chrispeach | Microwave Repair | 1 | 11-07-2007 11:49 AM |
