Discuss
Drilled holes in cabinet
 in
Microwave Repair
While fasten the MW to the Wall (it's an over the stove model) I inadvertently drilled holes through the
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Drilled holes in cabinet
  #1 (permalink)
Old 06-30-2008, 07:47 AM
dlb2147 dlb2147 is offline
Junior Member
dlb2147 is on a distinguished road
Question Drilled holes in cabinet
Brand: GE   Age: Less than 1 year
While fasten the MW to the Wall (it's an over the stove model) I inadvertently drilled holes through the bottom edge (in the corner) of the cabinet.
This morning my wife gave me the “good news, bad news” bit good news the MW is still on the wall, bad news she found metal shavings inside .
The screws are barely visible from the inside.
Is there any danger of leakage or heating the wall studs (fire)?
If there is no danger, what can I use to seal the hole?
Thanks for your help,
Danny
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 06-30-2008, 10:12 AM
abadfish66's Avatar
abadfish66 abadfish66 is offline
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
Any way you can post a picture of what your talking about? Are the screws coming through the inside cavity of the M/W?
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!!
Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up.
  #3 (permalink)
Old 07-01-2008, 01:41 PM
Junior Member
Default
I'll try to get a picture posted tomorrow, however when you open the door and look at the back lower edge the screws are barely visable. When I drilled the holes I was angling upward, so the screws broke through the inside floor(?) in the back corner where the back and the bottom are joined.
Thanks for your consideration and effort,
Danny
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
cabinet removal beadyiwoman Washer Repair 3 09-20-2008 04:49 PM
my in cabinet oven brandnew47 Oven Repair (including Ranges and Cooktops) 1 03-12-2008 05:38 PM
kenmore washer / 2 drain holes kathysmitley Washer Repair 2 12-14-2007 04:32 PM
kenmore washer / 2 drain holes kathysmitley Washer Repair 1 12-14-2007 12:20 PM
Cabinet removal jumbyway Washer Repair 1 08-23-2007 12:07 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
