My microwave was making a loud hum when turned on and did not heat the food. I tried disconnecting and reconnecting the power, but the unit continued to hum and died after about another 5 seconds of running. I have found a bad RECTIFIER (Diode) AppliancePratsPros Part Number: AP4362626, and a bad thermal fuse AppliancePratsPros Part Number: AP3769802 (Switch / Fuse combo). I was curious if I should check anything else prior to ordering, and also wanted to ask why Part Number: AP3769802 is sold as a Switch / Fuse combo?.. Any help would be greatly appreciated...
