Discuss
Burned microwave with metal pan
 in
Microwave Repair
I placed a metal cookie sheet in my above the stove microwave & burned a spot in the back. It'
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Burned microwave with metal pan
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 06-20-2008, 03:42 PM
ascrowell ascrowell is offline
Junior Member
ascrowell is on a distinguished road
Default Burned microwave with metal pan
Model Number: ge jvm1850bf001   Brand: GE   Age: 5 - 10 years
I placed a metal cookie sheet in my above the stove microwave & burned a spot in the back. It's more than just a surface burn. The white inner shell is damaged. It's not like I can see the wall behind the microwave as there is something there but the case is definitely damaged. Is this still safe to use since it's in the back? Can "waves" leak into through the wall into the room behind the microwave? Do I need to purchase a new microwave?
Thank you!!!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 06-20-2008, 03:46 PM
abadfish66's Avatar
abadfish66 abadfish66 is offline
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
If there is a hole through the cavity, and the hole is bigger than the holes you see in the door, then yes it will leak "microwaves" into the room, not to mention will probably start arcing at that point causing a fire hazard. I think I would get a new oven.
__________________
Who wants a chance to win $10,000 a week for the next 17 weeks? How about $250,000 if you have the most points after 17 weeks. The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!!
Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up.
  #3 (permalink)
Old 06-20-2008, 03:54 PM
Junior Member
Default
The hole is in the thin white interior cavity. I see metal or something behind it. I just want to clarify as I'm not sure my terms/names are correct. Thank you very much for your reply
  #4 (permalink)
Old 06-20-2008, 03:56 PM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
The metal you are seeing through the hole is the back of the microwave outer case, If you can see that, your micro is no good
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
metal ratteling while spinning bebonz Washer Repair 4 05-13-2008 06:43 PM
burned out VPruitt Refrigerator & Freezer Repair 1 02-11-2008 11:59 AM
Hinge on metal door is broken BAKERWG Oven Repair (including Ranges and Cooktops) 1 02-05-2008 06:49 AM
Burned out oven thermostat, I think NVP Oven Repair (including Ranges and Cooktops) 1 01-07-2008 03:56 PM
how do I remove the metal cabnet and repace a new drum belt Tinas7 Dryer Repair 2 01-03-2008 04:04 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
