| » Burned microwave with metal pan |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: ge jvm1850bf001 Brand: GE Age: 5 - 10 years
I placed a metal cookie sheet in my above the stove microwave & burned a spot in the back. It's more than just a surface burn. The white inner shell is damaged. It's not like I can see the wall behind the microwave as there is something there but the case is definitely damaged. Is this still safe to use since it's in the back? Can "waves" leak into through the wall into the room behind the microwave? Do I need to purchase a new microwave?
Thank you!!! |
If there is a hole through the cavity, and the hole is bigger than the holes you see in the door, then yes it will leak "microwaves" into the room, not to mention will probably start arcing at that point causing a fire hazard. I think I would get a new oven.
__________________
Who wants a chance to win $10,000 a week for the next 17 weeks? How about $250,000 if you have the most points after 17 weeks. The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!! Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up. |
The metal you are seeing through the hole is the back of the microwave outer case, If you can see that, your micro is no good
__________________
| Display Modes | |
| metal ratteling while spinning | bebonz | Washer Repair | 4 | 05-13-2008 06:43 PM |
| burned out | VPruitt | Refrigerator & Freezer Repair | 1 | 02-11-2008 11:59 AM |
| Hinge on metal door is broken | BAKERWG | Oven Repair (including Ranges and Cooktops) | 1 | 02-05-2008 06:49 AM |
| Burned out oven thermostat, I think | NVP | Oven Repair (including Ranges and Cooktops) | 1 | 01-07-2008 03:56 PM |
| how do I remove the metal cabnet and repace a new drum belt | Tinas7 | Dryer Repair | 2 | 01-03-2008 04:04 PM |
