Discuss
GE: Turntable turns, light on when door opens
 in
Microwave Repair
I have this mircrowave GE SpaceMaker JVM1631WJ03 for 2.5 years. Recently when I open the door, it may turns
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » GE: Turntable turns, light on when door opens
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 06-17-2008, 06:36 AM
nykhoa nykhoa is offline
Junior Member
nykhoa is on a distinguished road
Default GE: Turntable turns, light on when door opens
Brand: GE   Age: 1 - 5 years
I have this mircrowave GE SpaceMaker JVM1631WJ03 for 2.5 years. Recently when I open the door, it may turns on the light, turns the turntable, and I hear the sound like the microwave runs when the door is close. I have to close the door and select Clear/Off to turn it off.
Which part do I have to replace ?
Thanks for your advice.
Nykhoa
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 06-17-2008, 04:02 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Nykhoa,
Most likely the problem is a bad door switch (the lower one) which is stuck closed.
- The part number for the switch is AP2024367
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 06-19-2008, 09:10 AM
Junior Member
Default
Hi Gene,
Thanks a lot for your advice. I have never opened a microwave for repair. Do you think a novice can replace this switch ? Is there a diagram for this microwave so that I can start with ?
Thanks again,
Nykhoa
  #4 (permalink)
Old 06-19-2008, 12:06 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Nykhoa,
If you know major safety rules how to work with electrical appliances and you have a simple ohmmeter - you can do it. The diagram should be behind the top grille on the left side or inside the control panel.
__________________
  #5 (permalink)
Old 06-21-2008, 07:35 AM
Junior Member
Default
Gene, thanks again for your help. I have one more question so that I can order all the parts at one time, if I need more than one.
Besides the problem that I described, now when I close the door, it is difficult to make it start. With the door closed, I add minutes and press Start. The light turn on but the turntable does not run and I do not hear the normal sound when it runs properly. I have to open and close many times to make it start. Is this also caused by the bad switch or something else ?
Thanks for your advice,
Nykhoa.
  #6 (permalink)
Old 06-22-2008, 12:29 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Nykhoa,
As I said previously, the first failure suspect is the door interlock switch. You have to check it before taking any action.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
advantium: turntable and light always ON - main relay dcg9381 Microwave Repair 7 06-29-2008 12:26 PM
Open Microwave Door & Kenmore Turns On! TWA Microwave Repair 7 06-17-2008 02:09 PM
Cancel light blinking, randomly turns on decullen Dishwasher Repair 0 03-13-2008 10:31 AM
Ice shoot door constantly opens and closes and numbers onthe front flashing blanchard1213 Refrigerator & Freezer Repair 0 12-01-2007 09:43 AM
Microwave turntable turns erratically mrnester@charter.net Microwave Repair 0 10-23-2007 04:17 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
