| » GE: Turntable turns, light on when door opens |
Brand: GE Age: 1 - 5 years
I have this mircrowave GE SpaceMaker JVM1631WJ03 for 2.5 years. Recently when I open the door, it may turns on the light, turns the turntable, and I hear the sound like the microwave runs when the door is close. I have to close the door and select Clear/Off to turn it off.
Which part do I have to replace ? Thanks for your advice. Nykhoa |
Hi Nykhoa,
Most likely the problem is a bad door switch (the lower one) which is stuck closed. - The part number for the switch is AP2024367 Gene.
__________________
Professional appliance repair in Los Angeles, California. |
Hi Nykhoa,
If you know major safety rules how to work with electrical appliances and you have a simple ohmmeter - you can do it. The diagram should be behind the top grille on the left side or inside the control panel. Gene.
__________________
Gene, thanks again for your help. I have one more question so that I can order all the parts at one time, if I need more than one.
Besides the problem that I described, now when I close the door, it is difficult to make it start. With the door closed, I add minutes and press Start. The light turn on but the turntable does not run and I do not hear the normal sound when it runs properly. I have to open and close many times to make it start. Is this also caused by the bad switch or something else ? Thanks for your advice, Nykhoa. |
Nykhoa,
As I said previously, the first failure suspect is the door interlock switch. You have to check it before taking any action. Gene.
__________________
| Display Modes | |
| advantium: turntable and light always ON - main relay | dcg9381 | Microwave Repair | 7 | 06-29-2008 01:26 PM |
| Open Microwave Door & Kenmore Turns On! | TWA | Microwave Repair | 7 | 06-17-2008 03:09 PM |
| Cancel light blinking, randomly turns on | decullen | Dishwasher Repair | 0 | 03-13-2008 11:31 AM |
| Ice shoot door constantly opens and closes and numbers onthe front flashing | blanchard1213 | Refrigerator & Freezer Repair | 0 | 12-01-2007 10:43 AM |
| Microwave turntable turns erratically | mrnester@charter.net | Microwave Repair | 0 | 10-23-2007 05:17 PM |
