| » GE: Turntable turns, light on when door opens |
Hi.
All you need is a basic skills and common sense to replace the door switch. Provide the complete model number so I can get you the part number. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Hi.
Remove the cover and perform the continuity test at the upper and lower door switches (monitor and door sensing). With door open both switches should reed no continuity. with door closed - continuity. If the switches are good - replace the control board. Here are the breakdown diagram and Microwave replacement parts for General Electric PEB1590SM1SS MICROWAVE | AppliancePartsPros.com Thank you. Post the results. Simon.
__________________
Hi.
The "cover" is #1200 on the diagram if you open it. To check the continuity you need a multimeter. Here is an article on our forum: How To Check Continuity With Ohmmeter Simon.
__________________
| Display Modes | |
| Panasonic microwave turntable turns when door opened | nightdog | Microwave Repair | 0 | 02-06-2010 07:27 AM |
| turntable turns when door is closed and no cooking going on | ezduzit62 | Microwave Repair | 0 | 12-30-2009 11:50 AM |
| Microwave turntable turns erratically | mrnester@charter.net | Microwave Repair | 1 | 12-22-2008 06:30 AM |
| F9 code Oven turns off,lock light turns on,door does not lock | darling132 | Oven Repair (including Ranges and Cooktops) | 1 | 11-12-2008 02:06 PM |
| Kenmore turntable rarely turns | hub678 | Microwave Repair | 0 | 07-19-2008 01:51 PM |
