Discuss
GE: Turntable turns, light on when door opens
 in
Microwave Repair
You are welcome. Keep us posted. Gene. Ads By Google
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » GE: Turntable turns, light on when door opens
  #21 (permalink)
Old 11-24-2009, 12:59 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Ads By Google
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #22 (permalink)
Old 12-03-2009, 09:58 AM
Junior Member
joeba is on a distinguished road
Default
Quote:
Originally Posted by Gene View Post
Changing the lower switched fixed it!
A couple of notes from the install:
There are 3 switches, and the one I replaced was the bottom switch. The
top and bottom switch are the same switch, the middle is a door monitor switch and is a different part number. Either switch will fit in the latch housing assembly, so make sure you replace the correct switch. At first I replaced the middle switch and this did not fix the problem. I did not bother to look at the parts diagram to realize this was not the switch that I needed to replace.
I had to removed the entire latch assembly to replace the switch. No big deal just 2 screws
It's not obvious on how to remove the switch from the latch body. Just trying to pull it out does not work. You have to pry up on a little tab while pulling the switch out.
.5 total repair time, which would of gone faster if I had not replaced the wrong switch.
The deffective switch plunger lost it's "springy-ness" and was the reason the switch failed. Ten years and 3 kids worth of warming baby formula bottles really took a toll on it.
Thxs again Gene
  #23 (permalink)
Old 12-03-2009, 01:26 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Thank you for sharing your diagnosis and repair with us. Happy Holidays and good luck with your microwave.
__________________
  #24 (permalink)
Old 08-06-2010, 07:26 AM
Junior Member
seahaas is on a distinguished road
Default GE MW w same problem - light + fan on w door open
I am recently having this problem and came across this site. MW works fine, but goes on when door is open. I will be ordering new door switches to hopefully solve this problem. I have a few questions:
Should I replace all door switches?
Anything else worth replacing while I have this apart?
History: Unit is 14 ys old. Stopped working 2X in past. Both times, unit had power but keypad not responding. Both times, took out unit and manually made sure connections were tight. Unit worked fine for about 3 ys each time. We tend to open door before time is up and probably slam door too hard.
  #25 (permalink)
Old 08-15-2010, 11:52 AM
Junior Member
claudiadefries is on a distinguished road
Default Help!! Ge profile micro please tell me all the door switch part numbers
I need to replace all the door switches in my GE profile microwave as the fan goes on and turntable turns when I OPEN the door. I want to replace all door switches becasue I replaced one before, but shortly after it started doing it again. Can you please tell me all the generic doorswitch part numebrs GE JE1660WA03. It's 10 years old. I read the thread below - do you think it's emitting MV? What's the tin foil test?
Thank you Gene!!!!
Claudia
  #26 (permalink)
Old 08-15-2010, 11:55 AM
Junior Member
Default Need help for this ongoing GE microwave problem please!!
Thank you Gene!!!!
Claudia
  #27 (permalink)
Old 08-15-2010, 04:33 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Claudia,
There are three switches in your microwave and you can use the instructions posted earlier by joeba.
- The door sense switch (two of them needed) Part number: AP2024337
- The monitor switch Part number: AP2024338
Here are the breakdown diagrams and Replacement parts for General Electric JE1660WA03 Counter top microwave | AppliancePartsPros.com
__________________
  #28 (permalink)
Old 08-16-2010, 08:48 AM
Junior Member
Default GE microwave dor switch parts - generics?
Hi Gene, and thanks so much for your reply. Can you give me the generic equivalent part numbers for the ones you gave for my GE microwave JE1660WA03
AP2024338
AP2024337
thank you so much!!
Claudia
  #29 (permalink)
Old 08-20-2010, 07:59 AM
Junior Member
Exclamation Generic parts???
AP2024338
AP2024337
thank you so much!!
Claudia
  #30 (permalink)
Old 08-20-2010, 03:41 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The original parts are not expensive and I would not use aftermarket parts in such situation.
If you would like you can use Part number: AP4351467
instead of AP2024338 and Part number: AP4347888
instead of AP2024337
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Panasonic microwave turntable turns when door opened nightdog Microwave Repair 0 02-06-2010 07:27 AM
turntable turns when door is closed and no cooking going on ezduzit62 Microwave Repair 0 12-30-2009 11:50 AM
Microwave turntable turns erratically mrnester@charter.net Microwave Repair 1 12-22-2008 06:30 AM
F9 code Oven turns off,lock light turns on,door does not lock darling132 Oven Repair (including Ranges and Cooktops) 1 11-12-2008 02:06 PM
Kenmore turntable rarely turns hub678 Microwave Repair 0 07-19-2008 01:51 PM
