Discuss
GE: Turntable turns, light on when door opens
 in
Microwave Repair
Sorry, I was giving you the serial #. The model # is JE1660WA 003. Does this help? Thank you! Claudia
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » GE: Turntable turns, light on when door opens
  #11 (permalink)
Old 09-14-2009, 05:43 PM
Junior Member
claudiadefries is on a distinguished road
Default correct model #
Thank you! Claudia
  #12 (permalink)
Old 09-14-2009, 07:01 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
With the correct model number it's much easier.
Remove the top grill and open the control panel. The switches are on the left side, mounted on the frame (#26 on the diagram). Most likely the problem is a bad bottom switch. You can use the OEM switch or the after market switch I posted earlier.
- The GE switch Part number: AP2024337
Here are the breakdown diagram and replacement parts for the GE microwave Model JE1660WA03
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #13 (permalink)
Old 09-14-2009, 11:49 PM
Junior Member
jtran is on a distinguished road
Default
I have a GE Profile JTP95BA1. A couple months ago, it started having a failure symptom. Whenever I opened the door, the turn table motor was not off, but continuous rotated. This week, whenever I press “start”, it will have NO heat at all if the tray not rotated, but OK if the tray rotated. Please help me to pinpoint the failed component to fix it. Thanks,
JTran
  #14 (permalink)
Old 09-15-2009, 05:10 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
JTran,
Most likely the problem is a bad microwave control board. I would also check the door switches.
- The control panel assembly Part number: AP2030075
- The door switch Part number: AP2024337
Here are the breakdown diagrams and replacement parts for the GE oven/microwave combo Model JTP95BA1BB
__________________
  #15 (permalink)
Old 09-15-2009, 06:00 PM
Junior Member
Default
Hi Gene,
Thank you for your reply. I will check on the door sensing switch as your advices.
Regards,
JTran
  #16 (permalink)
Old 09-16-2009, 08:20 PM
Junior Member
Default
Hi Gene,
Once again thank you for your advices. I checked the relays on the control board. They are ok. I checked the switches of the interlock and found out the main switch broken. Actually all switches are the same. They just cut the un-used connector fordifferent configuration of normal-open(N.O.) or normal-closed(N.C.)
Regards,
JTran
  #17 (permalink)
Old 09-17-2009, 04:55 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
They are not exactly the same even if it looks like. Two interlock switches are NO and the monitor switch is NC.
__________________
  #18 (permalink)
Old 11-20-2009, 09:15 AM
Junior Member
joeba is on a distinguished road
Default
Quote:
Originally Posted by Gene View Post
Hi Nykhoa,
Most likely the problem is a bad door switch (the lower one) which is stuck closed.
- The part number for the switch is AP2024367
Having the same problem with a GE jvm1640wb002. What part do I replace and any tips on how to do it? Also, I can live with this since I'm in the planning stages of redoing the kitchen, if this poses no health risk, i.e. it's just running the fan and TT, and not emitting MV, is this true?
  #19 (permalink)
Old 11-20-2009, 02:00 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
...it's just running the fan and TT, and not emitting MV, is this true?...
You can not be sure about it. It's better to keep the microwave unplugged until it's fixed.
Quote:
... What part do I replace and any tips on how to do it?...
Most likely the problem is a bad door switch (#29 on the diagram). You have to remove the upper grill and open the control panel to access them.
Here are the breakdown diagrams and Microwave replacement parts for GE JVM1640WB002 | AppliancePartsPros.com
__________________
  #20 (permalink)
Old 11-23-2009, 10:54 PM
Junior Member
Default
Thxs Gene. I ordered the switch and did the old tin foil test to verify if the MV was emitting microwaves while this was happening and it appears that it is not.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Panasonic microwave turntable turns when door opened nightdog Microwave Repair 1 06-06-2015 03:06 PM
turntable turns when door is closed and no cooking going on ezduzit62 Microwave Repair 0 12-30-2009 12:50 PM
Microwave turntable turns erratically mrnester@charter.net Microwave Repair 1 12-22-2008 07:30 AM
F9 code Oven turns off,lock light turns on,door does not lock darling132 Oven Repair (including Ranges and Cooktops) 1 11-12-2008 03:06 PM
Kenmore turntable rarely turns hub678 Microwave Repair 0 07-19-2008 02:51 PM
