| » GE Spacesaver microwave issue |
Model Number: JVM1660WB001 Brand: GE Age: 5 - 10 years
The bulbs blew (surface lighting) and tripped the circuit breaker. When I replaced the bulbs, the surface lighting and the vent don't work (although rest of microwave is fine). Is there a fuse or something that I could replace? I unscrewed the bottom of the microwave but looked like I would have to take more apart to find out if a fuse even exists.
when that happens there is a trace on the circuit board that burns, I just resolder the missing trace with a piece of wire, but if that is not something you can do, you will need a new circuit board. To get to the circuit board, remove 2 screws on top above the vent grille, take grille off, remove 1 screw above the control panel, and take the control panel down..Make sure your microwave is unplugged. Now you can remove the 3 or 4 screws that hold the circuit board onto the panel. Look at the bottom of the board, and you will see the bad trace.
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!! Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up. |
A novice can do it, if you can solder, you can fix it for free, if you would rather get a new board, you can get it here. AP2631621
__________________
| Display Modes | |
| GE Spacesaver MW - Counts down, doesn't run | radioactive1 | Microwave Repair | 2 | 03-29-2008 10:37 AM |
| GE Spacesaver 2 shuts off after 5-10 sec. | Terry C | Microwave Repair | 4 | 01-05-2008 11:52 AM |
| GE Spacesaver Washer | bookie1959 | Washer Repair | 0 | 12-28-2007 07:19 PM |
| GE Spacesaver stackable WASHER | bookie1959 | Dishwasher Repair | 0 | 12-28-2007 04:30 PM |
| Spacesaver operates but doesn't heat | goecker | Microwave Repair | 0 | 09-28-2007 08:42 PM |
