Discuss
No door handle available from part sources
 in
Microwave Repair
When I check for replacement handles for this microwave, it does not show any numbers for handles. It only shows
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » No door handle available from part sources
  #1 (permalink)
Old 09-04-2007, 07:45 AM
billwh billwh is offline
Junior Member
billwh is on a distinguished road
Default No door handle available from part sources
Model Number: JVM290WV01   Brand: GE   Age: More than 10 years
When I check for replacement handles for this microwave, it does not show any numbers for handles. It only shows parts for replacing the entire door. Do I have to replace the whole door? How do I remove the door/hinges? The handle is secured from screws on the inside of the door. The inside door has star shaped screws, not phillips.
Any help would be greatly appreciated. Thanks!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-04-2007, 11:27 AM
DEPSERV DEPSERV is offline
Junior Member
DEPSERV is on a distinguished road
Default
Yes It Only Comes With Door Call For More Info **************
Post edited by admin. Reason: advertising
  #3 (permalink)
Old 09-04-2007, 12:51 PM
Admin / APP Team Admin / APP Team is offline
Administrator
APP Team
Admin / APP Team has disabled reputation
Default
Bill,
The handle is only available together with the door. GE does this to some of their microwave models for whatever reason.
To replace the door, you'll need to unplug and remove the entire microwave, set it on a flat surface, discharge the capacitor, and remove the case. Not a simple job. What makes it worse is the door assembly sells for around $161. From what I can tell, this microwave is probably about 8-10 years old, if not more. Might want to consider replacing the micro altogether. As an option, you can try contacting your local microwave repair shops - they always have old micrwave parts laying around and you might find a similar door you can use a handle from.
Hope this helps.
  #4 (permalink)
Old 09-04-2007, 01:39 PM
Junior Member
Default
Thanks for your help!!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Handle Replacement Tim Microwave Repair 14 02-11-2008 07:13 PM
Replacing door panel & handle Laurence Microwave Repair 2 01-13-2008 09:09 PM
loose oven door handle duck Oven Repair (including Ranges and Cooktops) 1 07-31-2007 07:04 PM
what part do i need? agitator Washer Repair 1 07-27-2007 05:45 PM
How to put new handle on shelly Microwave Repair 1 07-24-2007 01:03 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
