Discuss
Fuse burned out?
 in
Microwave Repair
When we try to cook, the timer runs but there is no noise, no heat, nothing. The clock works and
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Fuse burned out?
  #1 (permalink)
Old 04-04-2010, 06:30 PM
Junior Member
iliffsd is on a distinguished road
Default Fuse burned out?
Model Number: MW8650XR   Brand: Whirlpool   Age: More than 10 years
When we try to cook, the timer runs but there is no noise, no heat, nothing. The clock works and the display lights, so it's getting power. Is this simply a burned out fuse (I hope) or is the dang thing just worn out (it's 25 years old). If it's something simple, that's great. If not, I know we're way beyond time to replace her.
Ads By Google
Related Models
Whirlpool MW8650XR0 Microwave
Whirlpool MW8650XS0 Microwave
Whirlpool MW8650XS1 Microwave
Whirlpool MW8650XS2 Microwave
Whirlpool MW8650XS3 Microwave
Whirlpool MW8650XS4 Microwave
Whirlpool MW8650XS5 Microwave
Whirlpool MW8650XS6 Microwave
Whirlpool MW8650XS7 Microwave
Whirlpool MW865EXR0 Microwave
Whirlpool MW8700XL0 Microwaves*
Whirlpool MW8700XL2 Microwaves*
Whirlpool MW8700XR0 Microwaves*
Whirlpool MW8700XS0 Microwaves*
Whirlpool MW8700XS1 Microwaves*
Whirlpool MW8700XS2 Microwaves*
Whirlpool MW8750XL0 Microwaves*
Whirlpool MW8750XL2 Microwaves*
Whirlpool MW8750XP0 Microwaves*
Whirlpool MW8800XR0 Microwaves*
Whirlpool MW8800XS0 Microwaves*
Whirlpool MW8800XS1 Microwaves*
Whirlpool MW8800XS2 Microwaves*
Whirlpool MW8800XS4 Microwaves*
 MW880BKA MWAVE- CNTRTP / STAND ALONE
 MW880BKA/XAA MWAVE- CNTRTP / STAND ALONE
 MW880BLA MWAVE- CNTRTP / STAND ALONE
 MW880BLA/XAA MWAVE- CNTRTP / STAND ALONE
 MW880BSA MWAVE- CNTRTP / STAND ALONE
 MW880BSA/XAA MWAVE- CNTRTP / STAND ALONE
 MW880GRA MWAVE- CNTRTP / STAND ALONE
 MW880GRA/XAA MWAVE- CNTRTP / STAND ALONE
 MW880KSA MWAVE- CNTRTP / STAND ALONE
 MW880KSA/XAA MWAVE- CNTRTP / STAND ALONE
 MW880RDA MWAVE- CNTRTP / STAND ALONE
 MW880RDA/XAA MWAVE- CNTRTP / STAND ALONE
 MW880RSA MWAVE- CNTRTP / STAND ALONE
 MW880RSA/XAA MWAVE- CNTRTP / STAND ALONE
 MW888STB MWAVE- CNTRTP / STAND ALONE
Whirlpool MW8900XS0 Microwaves*
Whirlpool MW8900XS1 Microwaves*
Whirlpool MW8900XS2 Microwaves*
Whirlpool MW8900XS3 Microwaves*
Whirlpool MW8900XS4 Microwaves*
Whirlpool MW8900XS5 MICROWAVE
Whirlpool MW8900XS6 Microwaves*
Whirlpool MW8901XS0 Microwaves*
 MW945WB MWAVE- CNTRTP / STAND ALONE
 MW965BB MWAVE- CNTRTP / STAND ALONE
 MW965BB/XAA MWAVE- CNTRTP / STAND ALONE
 MW965WB MWAVE- CNTRTP / STAND ALONE
 MW965WB/XAA MWAVE- CNTRTP / STAND ALONE
Amana MW96T MWAVE- CNTRTP / STAND ALONE
Amana MW96T Mwave - Cntrtp / Stand Alone
Magic Chef MWCP1085 WASHER-TOP LOADING
Magic Chef MWCP1085-A WASHER-TOP LOADING
Amana MWD365 MWAVE- MOUNTED OVER RANGE/WO
Amana MWD366 MWAVE- MOUNTED OVER RANGE/WO
Amana MWD36610 MWAVE - FAMILY SIZE (60 HZ)
Amana MWD366MN002 RANGE- S/C S/I DDRAFT GAS
Maytag MWF2100AWB WATER FILTRATION SYSTEM
Maytag MWF2100AWS WATER FILTRATION SYSTEM
Maytag MWF3100AWB WATER FILTRATION SYSTEM
Maytag MWF3100AWS WATER FILTRATION SYSTEM
Maytag MWF3500AWS WATER FILTRATION SYSTEM
Maytag MWF4100 WATER FILTRATION SYSTEM
Maytag MWF4100AWS WATER FILTRATION SYSTEM
Maytag MWF4200 WATER FILTRATION SYSTEM
Maytag MWF4200AWS WATER FILTRATION SYSTEM
Maytag MWF4300 WATER FILTRATION SYSTEM
Maytag MWF4300AWS WATER FILTRATION SYSTEM
Maytag MWF4500AWS WATER FILTRATION SYSTEM
Whirlpool MWFW8300SW01 AUTOMATIC WASHER
Whirlpool MWFW8300SW02 AUTOMATIC WASHER
Whirlpool MWFW8500SR01 AUTOMATIC WASHER
Whirlpool MWFW8500SR02 AUTOMATIC WASHER
Whirlpool MWFW9200SQ00 AUTOMATIC WASHER
Frigidaire MWL111RBW0 Frg(v1) / 27 " Washer
Frigidaire MWL111RBW1 Frg/27" Washer
Frigidaire MWL111RBW2 Frg(v0) / Washer
Frigidaire MWL411RBD0 Frg(v2) / 27 " Washer
Frigidaire MWL411RBW0 Tap(v7) / 27 " Washer
Frigidaire MWL411RBW1 Frg(v1) / Washer
Frigidaire MWL411RBW2 Tap(v11) / Washer
Frigidaire MWL411RBW3 Tap(v12) / Washer
Frigidaire MWL411RBWD0 Gib(v10) / 27 " Washer
Frigidaire MWL411RBWL0 Frg(v2) / 27 " Washer
Frigidaire MWL411RBWW0 Frg(v1) / 27 " Washer
Amana MWP211 MWAVE- CNTRTP / STAND ALONE
Amana MWR212 MWAVE- CNTRTP / STAND ALONE
Amana MWR213 MWAVE- CNTRTP / STAND ALONE
Amana MWR214 MWAVE- CNTRTP / STAND ALONE
Amana MWR365 MWAVE- CNTRTP / STAND ALONE
Amana MWR36510 MWAVE- MOUNTED OVER RANGE/WO
Frigidaire MWS445RES0 Frg(v1) / Washer
Frigidaire MWS445RES1 Frg(v0) / Washer
Frigidaire MWS445RES2 Frg(v0) / Washer
Frigidaire MWS445RET0 Frg(v2) / Washer
Frigidaire MWS445RFS0 Frg(v0) / Washer
Frigidaire MWS445RFS1
Frigidaire MWS445RFS2 Frg(v0) / Washer
Frigidaire MWS833AS2 Universal/washer
Amana MWT344/1001 MWAVE - FAMILY SIZE (60 HZ)
Amana MWT366/1001 MWAVE - FAMILY SIZE (60 HZ)
Amana MWT4441D MWAVE- MOUNTED OVER RANGE/WO
Amana MWT4451D MWAVE- MOUNTED OVER RANGE/WO
Amana MWT4451D01 MWAVE - FAMILY SIZE (60 HZ)
 MWT4451WW MWAVE- MOUNTED OVER RANGE/WO
Maytag MWT4451WW Mwave - Mounted Over Range/wo
Amana MWT4451WW01 MWAVE - FAMILY SIZE (60 HZ)
Amana MWT4461D MWAVE- MOUNTED OVER RANGE/WO
Amana MWT4461WW MWAVE- MOUNTED OVER RANGE/WO
Amana MWT4661D MWAVE- MOUNTED OVER RANGE/WO
Amana MWT4661W MWAVE- MOUNTED OVER RANGE/WO
Amana MWT4661WW MWAVE- MOUNTED OVER RANGE/WO
Frigidaire MWV150KBA MICROWAVE
  #2 (permalink)
Old 04-04-2010, 09:22 PM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
Probably not...most MW fuses are inline with the power cord. If fuse opens, you don't even get a display. You're probably not getting power past your power transformer. You need to check to see if you're getting 120VAC to the transformer. If you are, the transformer may be the problem. If you're not, the problem is the control board.
  #3 (permalink)
Old 04-05-2010, 09:44 AM
Junior Member
Default
A follow-up question - how do I check that we're getting 120VAC to the transformer and is that something easy to do?
Also - if the transformer is the problem, is that as espensive repair as I think it is? If so, buying a new MW is probably best.
Quote:
  #4 (permalink)
Old 04-05-2010, 10:11 AM
Senior Expert
APP Volunteer
Default
Here's a breakdown of the parts. The transformer is #1 in the drawing. If you don't have any experience testing live circuits, it's best to take it to a pro. Part number: AP3118114
. To test it, just unplug the MW and pull the cover off. For safety, discharge the capacitor by shorting across its terminals. Remove the wires that go from the transformer to the magnetron side of the circuit. Protect them from wire-to-metal or wire-to-wire contace. Plug the oven back in and select a cook mode. while it's "cooking", check the primary wires at the transformer terminals for 120VAC. If there's not enough, or none at all, the problem is a bad control board. If you get the required voltage, the problem lies with one (or more) of the high voltage components.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Burned but not baking Kyle Burmaster Oven Repair (including Ranges and Cooktops) 2 12-24-2009 08:00 AM
Burned Cookies bogeyman Oven Repair (including Ranges and Cooktops) 1 06-01-2009 02:11 PM
burned up? steveandtonic Dryer Repair 1 05-15-2009 07:34 PM
my kenmore almost burned me help me fix it Refrigerator & Freezer Repair 1 07-29-2008 11:36 AM
burned out VPruitt Refrigerator & Freezer Repair 1 02-11-2008 11:59 AM
