Discuss
Open Microwave Door & Kenmore Turns On!
 in
Microwave Repair
This Kenmore microwave worked fine for 4 years until yesterday. Now, when you open the door, the thing turns on,
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Open Microwave Door & Kenmore Turns On!
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 06-02-2008, 11:04 AM
TWA TWA is offline
Junior Member
TWA is on a distinguished road
Default Open Microwave Door & Kenmore Turns On!
Model Number: 721.63252300   Brand: Kenmore   Age: 1 - 5 years
This Kenmore microwave worked fine for 4 years until yesterday. Now, when you open the door, the thing turns on, the platter turns, and it is microwaving. When you close the door, and it stops. If you need to cook food, it still works normally with the door shut - even turns off on time. But open that door, and it turns on again.
Obviously, this is not safe, because I think microwaves are escaping.
My initial impression is a circuit board malfunction. It almost acts like it needs to be reset - or rebooted as with a computer. I don't know how to do that, however, and unplugging the thing for a minute and plugging it back in does not make a difference.
Mechanically, the door opens and closes normally, and the latches look OK.
Please let me know any ideas on this odd problem. Such as, what parts might be at fault, and how to fix it.
Thanks,
TWA
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 06-02-2008, 03:45 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Quote:
Originally Posted by TWA View Post
... when you open the door, the thing turns on, the platter turns, and it is microwaving...
How did you know it is "microwaving" when the door is open?
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 06-03-2008, 09:45 AM
TWA TWA is offline
Junior Member
Default
Gene, I checked to see if food became hot when the door is open and the fan and turntable are working. In fact, the food did not heat up, so I think you are right, and I'm now hopeful there is an easy solution here.
The microwave works properly on the timed cooking when the door is closed.
When the door is opened, the fan continues to run, and the turntable continues to turn. Interestingly, when you open the door repeatedly, the turntable changes directions almost every time. One time, however, the turntable did not move, and the fan did not turn on. So, now I wonder if there is something stuck in there that a bit of WD-40 might cure. In particular, I wonder about the lower door latch, which seems to have something to do with this problem. I don't have a diagram, and the manual is no help.
I'm very interested to read your suggestions before I take this thing apart and start spraying WD-40.
Tom
  #4 (permalink)
Old 06-03-2008, 10:52 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Tom,
Most likely the problem is a bad secondary interlock switch which is usually located on the bottom part of the door frame. DO NOT use WD-40 on any electric parts - it will cause a short.
I'm not able to provide more accurate information because the model number you posted does not come up.
__________________
  #5 (permalink)
Old 06-03-2008, 11:51 AM
TWA TWA is offline
Junior Member
Default
Thank you Gentleman Gene,
I was able to find a diagram of the part #4002 at Sears Parts:
KENMORE | Model #72163252301 | MICROWAVE | LATCH BOARD PARTS | SearsPartsDirect.com from Sears
I read somewhere it is a good idea to change out both switches if one of them goes bad. They will send me the Primary and Secondary Interlock Switches for $20 delivered. If your company sells these same parts, I'd prefer to get them from you, so please let me know.
However, I still wonder if there is a mechanical part causing the problem, so I think I'll open up the microwave and take a look at the situation. I understand that it is probably not such a good idea to start spraying WD-40 on everything, especially electrical parts. My general impulse is to either use the WD, or else duct tape! I'll also try to keep the hammer in the toolbox, although that's worked in the past...
Thanks,
Tom
  #6 (permalink)
Old 06-03-2008, 01:20 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Tom,
After you installed the new switches, with the control panel removed, check how they are engaged by the door latch and adjust it if needed.
- The part number for the interlock switch is AP3153831
This switch can be used as a replacement for a monitor switch as well. You have to break off an unneeded terminal.
__________________
  #7 (permalink)
Old 06-17-2008, 02:04 PM
TWA TWA is offline
Junior Member
Default Case Closed
Dear Gene - aka Appliance Sherlock Holmes,
Thanks so much for your advice. I installed the switches I ordered online, and voila! the problem is solved. When I opened the case or this Kenmore Microwave, I discovered a wiring diagram folded up in a little plastic holder, which was nice. Between that and the diagram I was able to download from sears.com parts, and your advice, the repair was very clear. Thanks again.
Tom
  #8 (permalink)
Old 06-17-2008, 02:09 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Tom,
I'm glad you were able to fix it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Sharp countertop microwave open door button broken ldc Microwave Repair 0 05-29-2008 12:07 PM
Microwave door will not open tomR Microwave Repair 3 03-30-2008 07:26 PM
kenmore microwave door repair rlavann Microwave Repair 1 03-04-2008 04:00 PM
Kenmore HE 2Plus Door Won't Open kenmorehe2 Washer Repair 0 02-16-2008 03:06 PM
Sears Kenmore Microwave door handle fredez Microwave Repair 0 02-16-2008 04:34 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
