My Advantium microwave has all the normal functions but does not heat food. I removed it and checked the oven cavity TCO per the diagostic paperwork in the ove.
For this sensor, blk-red resistance is supposed to be 6.2 kohm and I measured 6.8 kohm. The other two resistances (red-white and black white) are supposed to be 3.1 kohm and I measured 3.4 k ohm. I made the measurements per the instructions (disconnected the lead from the board and made the measurements).
Are these measurements within the normal range? If so, any other suggestions on what to check?
Thanks, Mike
