Discuss
spacemaker XL touch keypad
 in
Microwave Repair
about a year ago the numbers 1 thru 6 on the keypad (they also serve as express cook #'s) on
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » spacemaker XL touch keypad
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 05-25-2008, 02:25 PM
rforwal rforwal is offline
Junior Member
rforwal is on a distinguished road
Default spacemaker XL touch keypad
Model Number: jum1440bh01   Brand: GE   Age: 1 - 5 years
about a year ago the numbers 1 thru 6 on the keypad (they also serve as express cook #'s) on my microwave stopped working. since then we have to use the "add 30 seconds" button pressed several times to heat most everything. everything else on the pad works. owners manual tells nothing for this problem. is there something i can fix or reset or do i need a new keypad and if so, how do i replace,i don't see any screws.thank you
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-28-2008, 10:17 PM
abadfish66's Avatar
abadfish66 abadfish66 is offline
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
To get to the control panel, there are 2 screws at the top of the vent cover above the door, take those off and remove the vent cover. next you will see 1 screw for the control panel remove it. Push upward on the control panel as it sits in slots. and drop the front down twards you there you have access to the control board. Pull the ribbon cable out of the board and clean the ends with a paper towel. put the ribbo cable back in and see if it works. Please unplug the microwave before disassembly. Keep me posted
  #3 (permalink)
Old 06-03-2008, 08:26 AM
Junior Member
Default
thanks for the info. while trying to remove the ribbon cable plug a piece that seemed to be a lock lifted up but i still couldnt remove plug. i didnt want to pull too hard being afraid to break the pins or circuit board.i also tried wiggling but no good. even though after puting back control panel and plugging in (it works now) i would still like to know how to remove for future repair
  #4 (permalink)
Old 06-03-2008, 08:34 AM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
on some of the boards, that piece you say came off is what locks the ribbon in place, some lift up to unlock, and some you have to push away from the ribbon to unlock
__________________
Who wants a chance to win $10,000 a week for the next 17 weeks? How about $250,000 if you have the most points after 17 weeks. The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!!
Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Keypad on DACOR 36S erincook Oven Repair (including Ranges and Cooktops) 1 05-13-2008 11:38 AM
Replaced keypad, Meomaxy Oven Repair (including Ranges and Cooktops) 1 01-12-2008 11:38 PM
Dacor raised vent keypad removal sabraham Oven Repair (including Ranges and Cooktops) 0 11-20-2007 10:23 PM
Keypad doesnot work Hari Microwave Repair 2 11-18-2007 03:25 PM
Jennair problem with keypad after new clock glenn.martz Oven Repair (including Ranges and Cooktops) 2 10-29-2007 07:16 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
