Discuss
Nothing Operating after Power Problem
 in
Microwave Repair
Power problem, we lost the neutral wire to the house. The board was clearly fried near the bottom, below relays.
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Nothing Operating after Power Problem
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 05-20-2008, 09:51 PM
bigburn64 bigburn64 is offline
Junior Member
bigburn64 is on a distinguished road
Default Nothing Operating after Power Problem
Model Number: JVM1339BW02   Brand: GE   Age: 5 - 10 years
Power problem, we lost the neutral wire to the house. The board was clearly fried near the bottom, below relays. With the new board installed still no sign of life / light. Checked 3 of 4 TCO, Bottom–Closed, Hood-Open, Cavity-Closed (thought that would be the charm). Using manual for 1400/1600 series (found in another thread & looks pretty close to schematic in cabinet) which notes MGT TCO on neutral line so fan & cook top light would still work. Any ideas? Is the "smart board’ part of the PCB (which is what I thought I replaced #AP2025946). Thanks in advance!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-21-2008, 08:24 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Did you check the in-line fuse?
Did you check for 120VAC at the power outlet? Try to plug it in a different outlet.
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 05-21-2008, 09:05 PM
Junior Member
Default
Yes, verified the outlet had 110V & fuse OK, all good! I have done further tracing and verified w/ OHM meter that all 4 TCOs are NO & NC as expected. Also I just completed checking out the keypad, all keys are functional to the point of they have continuity when pushed & are open when not depressed. I have traced the power side of thins from the hot prong on plug up to the back of what I think is the main relay on the back of the PCB, All Good! Also traced the neutral from the plug prong back to the PCB (further proof the MGR TCO is OK). What are the chances the replacement PCB is Bad? It seems to be my only option at this point. As I said, I cannot get the any of the lights to go on or exhaust fan to run. I did get the cooling fan to run when I jumped out the Hood TCO, but that looks to be external from the PCB. Thanks for help. In reading many of you threads, we home fixers are very lucking someone with all of your experience is willing to share your knowledge. Thanks Dennis!
  #4 (permalink)
Old 05-22-2008, 05:14 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Sounds like the new PCB is defective.
Call the customer service to exchange the part under the part warranty.
__________________
  #5 (permalink)
Old 06-19-2008, 10:04 AM
Junior Member
Default
The 2nd replacement board had the same result, nothing operating at all. Further troubleshooting confirmed I had 120V power to the board and out to LVT, but no low voltage power coming into the board to power keys or display. A new LVT along with a replacement board solved the problem.
  #6 (permalink)
Old 06-19-2008, 12:09 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I'm glad you were able to fix it. Good job!
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer squealing, but operating correctly TLC77 Washer Repair 1 05-14-2008 02:04 AM
Igniter spark operating wrong side chaswerner Oven Repair (including Ranges and Cooktops) 0 03-27-2008 03:17 PM
Dishwasher stopped operating KKaz Dishwasher Repair 2 01-11-2008 06:29 AM
Microwave not operating DrewG Microwave Repair 0 12-09-2007 08:05 AM
Operating Refrigerator in Cold Temperature Environments SUhoopfan Refrigerator & Freezer Repair 1 12-06-2007 02:14 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
