Discuss
Oven turns on ny itself
 in
Microwave Repair
I have a GE Profile Convection Microwave Oven that turns on by itself. When that happens, none of the controls
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Oven turns on ny itself
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 05-16-2008, 11:19 AM
nafpic nafpic is offline
Junior Member
nafpic is on a distinguished road
Default Oven turns on ny itself
Model Number: JVM1790SK01   Brand: GE   Age: 1 - 5 years
I have a GE Profile Convection Microwave Oven that turns on by itself. When that happens, none of the controls work. I can only stop it by pulling out the plug.
The oven takes a long time baking using the convection option.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-17-2008, 03:21 PM
glen65 glen65 is offline
Senior Expert
APP Volunteer
glen65 is on a distinguished road
Default
Does it start all by its self when it’s sitting idle without using it?
Or does it do this in the midst of –or shortly after usage?
When it starts by itself what does the display do (or what does it show)?
Does it count down – or does it just show the time of day?
  #3 (permalink)
Old 05-19-2008, 10:30 AM
Junior Member
Default
Yes, it does seem to happen shortly after using it. When it turns on by itself, the display shows the time.l
  #4 (permalink)
Old 05-19-2008, 12:10 PM
Senior Expert
APP Volunteer
Default
The next time it does this "dont open" but rather
slightly pull and push on the oven door while it runs
does the unit shut off? If not then try shutting it off by
opening the door.
  #5 (permalink)
Old 05-20-2008, 09:07 AM
Junior Member
Default
We tried opening and shutting the door but that didn't help. None of the controls worked. The only thing that we were able to do to shut it off, was pull out the plug.
  #6 (permalink)
Old 05-20-2008, 09:42 AM
dashusky dashusky is offline
Junior Member
dashusky is on a distinguished road
Default
I am having the same problem with an LG over the range microwave. The vent will just turn on by itself when its not being used. The only way to turn it off is to unplug it. None of the controls wotk and opening and shutting the door doesnt help.We are not cooking when this happens and have even woken up in the morning to find it running. ve had repairmen out and all have different ideas but not one pat answer.
  #7 (permalink)
Old 05-20-2008, 10:50 AM
Senior Expert
APP Volunteer
Default
Quote:
It was running with the door open?
  #8 (permalink)
Old 05-21-2008, 07:31 AM
Junior Member
Default
Yes, it runs with the door open...
  #9 (permalink)
Old 05-21-2008, 12:29 PM
MjB MjB is offline
Junior Member
MjB is on a distinguished road
Default
I have read numerous account of GE built-in microwaves that "turned on by themselves" and eventually caught fire. 7 of them in the state of FL resulted in extensive fire damage to a home. At least one of these microwave ovens was recalled by GE. look up consumer reports GE microwaves to find out more, or contact GE directly to find out if your model is one of the models that has been recalled. If it's not, contact them anyway to tell them about it (although, from the reports I read, they know full-well about these problems and pretend that they don't). Many of the reports said the problem was a faulty "magnetron"... it was leaking and causing sparking, which led to fire. Try citing that as the problem and see if they'll fix it for you.
  #10 (permalink)
Old 05-22-2008, 07:47 AM
Senior Expert
APP Volunteer
Default
Some areas that would needed to be looked at are,
Door interlock switches or there could be a fault
within the control panel itself.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Broiler Turns On/ Oven Bake Will Not TRINIDAD Oven Repair (including Ranges and Cooktops) 0 04-26-2008 06:34 AM
Washer inner tub turns cw and ccw clarktim Washer Repair 0 04-04-2008 03:25 PM
GE Profile Convention Oven Turns Off When Preheating martys Oven Repair (including Ranges and Cooktops) 3 01-26-2008 02:59 PM
Oven Turns On All By Itself!!! CHRISTOPHER Oven Repair (including Ranges and Cooktops) 3 11-29-2007 11:44 AM
Dishwasher turns on and off slangzang Dishwasher Repair 1 11-11-2007 04:19 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
