Discuss
GE no heat
 in
Microwave Repair
this unit has quit heating, It makes a loud racket when activated.I took the unit apart,the capacitor seems
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » GE no heat
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 05-12-2008, 05:36 AM
jkhlex jkhlex is offline
Junior Member
jkhlex is on a distinguished road
Default GE no heat
Model Number: JES1039WJ01   Brand: GE   Age: Less than 1 year
this unit has quit heating, It makes a loud racket when activated.I took the unit apart,the capacitor seems to test fine,I am unsure regarding the diode, I am using a Fluke 83 digital meter and I cannot get a resistance measurement at all ,or should I say there is infinite resistance and I cannot measure anything front to back.It is not shorted.If I disconnect the load(magnetron)the noise decreases a lot. The resistance measurement between the Filament F and FA to ground are 19.3 ohms. This seems to indicate to me the mag is shorted to gnd. the filament resistance is .3 ohms which seems normal to me . There is a smell I think(electrical) emminating from the mag when you are running the oven. The High voltage transformer secondary that powers the HV loop with the cap and diode reads 92 ohms, the schematic has a value of 72 ohms across this part of the secondary. According to the warranty the mag has a limited 5 year warranty. What is your opinion? Thanks....Jim
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer will not heat during timed drying; will heat for short time while auto drying mg13nj Dryer Repair 9 03-22-2008 11:40 AM
Heat but not drying, seems like heat is not blowing good Papa1 Dryer Repair 2 10-07-2007 10:11 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
