Discuss
GE Over-The-Range MW Won't Heat. . .
 in
Microwave Repair
First post here. I've spent nearly 30 hours taking this unit apart, measuring key H.V. components (diode, magnetron,
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » GE Over-The-Range MW Won't Heat. . .
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 05-09-2008, 11:34 AM
FalconEddy FalconEddy is offline
Junior Member
FalconEddy is on a distinguished road
Default GE Over-The-Range MW Won't Heat. . .
Model Number: JVM1460BA01   Brand: GE   Age: 5 - 10 years
First post here.
I've spent nearly 30 hours taking this unit apart, measuring key H.V. components (diode, magnetron, capacitor), door switches, thermostats, and flame sensors.
Checked for loose wiring/connectors, bad fuses, and broken wires inside their PVC or cloth insulation jackets.
Performed Key Panel, Smart Board, and Sensor tests; but I still cannot locate the reason(s) why it's not heating. Both the H.V. cap and diode have been replaced even though the originals tested out ok.
Utility supply was measured at 119.3VAC
The H.V. tranny tested out with the following results:
Primary winding: .4Ω
Secondary winding: 68.5Ω (schematic shows nominal as 79Ω) This was measured from the white wire on the tranny to ground.
Filament winding: 0Ω
Primary winding to ground: Infinite
Filament winding to ground: Infinite
The Magnetron tested out with the following results:
Resistance between the two filament terminals: .1Ω
Resistance from filament to Magnetron chassis: Infinite
Now, I don't have a meter that will accurately measure resistance (milli-ohms) in the windings; but the schematic lists them as 430mΩ on the primary and 100mΩ on one of the secondary legs.
Anyone have some ideas??? I'm completely stumped on this one.
Thanks,
FalconEddy
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-09-2008, 12:43 PM
glen65 glen65 is offline
Senior Expert
APP Volunteer
glen65 is on a distinguished road
Default
Try a voltage test,
“Carefully” check to see if
you are getting 120 Volts AC to the primary
winding of the transformer when the unit is running.
  #3 (permalink)
Old 05-09-2008, 04:17 PM
Junior Member
Default
Quote:
Originally Posted by glen65 View Post
Try a voltage test,
Already did that. Getting 119.3VAC from the utility to the H.V. primary. I tested it off the big switching relay on the Smartboard. It went from a few millivolts right up to 119.3VAC right after engaging the start button.
I also measured amperage during operation. No surprise that it was only between 3.5A to 4.5A.
Next step(s)?
At this point I'm tempted to change out the magnetron (I have a replacement here) just to see if I was getting false 'good' readings when I tested it. But, that still doesn't explain the low current draw. . . does it?
. . Falcon
  #4 (permalink)
Old 05-09-2008, 05:16 PM
Senior Expert
APP Volunteer
Default
Next step(s)?
. . Falcon
Ok youre getting 120VAC off of the smart board relay but are you getting it at the transformer primary terminals themselves?
  #5 (permalink)
Old 05-10-2008, 04:52 PM
Junior Member
Default
Yes.
Sorry if I wasn't clear enough about that in my first reply.
Voltage was measured both on the wiring at the smartboard relay, and the primary terminals where the wires make the connection.
I've already measured all pertinent wiring from end to end without being connected to ensure there were no open conditions.
. . Falcon
  #6 (permalink)
Old 05-10-2008, 06:01 PM
Senior Expert
APP Volunteer
Default
When you checked the diode did you get
a reading with the probes connected in one
direction and nothing when you reversed them?
  #7 (permalink)
Old 05-10-2008, 06:57 PM
Junior Member
Default
Although the original diode appears to be open, two other diodes I have (right out of the factory sealed package) both also test open (in both directions). Since my meters will see the forward voltage higher than 2 volts, this HV diode cannot be checked on them. My three meters will all check smaller diodes and bridge rectifiers (1N4004, 1N4007, Vishay GBPC606-E4) with no problem (which does me absolutely no good in this case), and I've verified all three meters are working accurately.
I've also got a vintage Simpson meter (non-digital) around here somewhere, but haven't been able to locate it. Hopefully, my wife didn't take it to the Goodwill store with my o-scope that only needed a new probe.
As I initially mentioned, note that I have used one of the new replacement HV diodes with the same results; as well as a new HV cap.
. . Falcon
  #8 (permalink)
Old 05-10-2008, 07:45 PM
Senior Expert
APP Volunteer
Default
You can check those 4000 series diodes with
just about anything. You need a meter that’s running
at least a 9 volt battery to get anything out those HV diodes.
It’s probably a Simpson 260, just hope that one didn’t walk
away from you. A new one is about 250 -300 bucks.
You would be able to check the HV diodes with that one.
you would just need to set it on R times 10,000.
If you locate it -hang on to it. I still have mine
and I still use it quite a bit.
Ok.. provided everything is wired correctly and you are
getting 120VAC at the primary of the transformer, about
the only two things left would be 1. the transformer
is not putting out HV (bad secondary) or 2. the mag is bad.
Based on youre earlier post I suspect the latter of the two.
  #9 (permalink)
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
According to all tests performed and their results it looks to me that the first failure suspect is the magnetron.
__________________
Professional appliance repair services in Orange County, California.
  #10 (permalink)
Old 05-10-2008, 08:13 PM
Junior Member
Default
Yup. That's why I've been trying to find it (Simpson).
If not, I could whip up a 15v HV diode analyzer early next week with my variac and a couple of other component parts.
But, seeing as how I've already got the mag, I may as well just install it (and reuse the t-stat on the original). The worst that could happen is that it still won't heat.
It may actually be the HV tranny since there's not really a loud noise coming from it. It has that 'bad transformer hum' sound during operation. But, the mag is the most likely candidate.
Mother's day tomorrow, so I won't get around to it until Monday at this point. I'll let you know after I change out the mag.
Thanks,
. . Falcon
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Range shuts off during pre-heat MJV66 Oven Repair (including Ranges and Cooktops) 0 04-04-2008 11:13 AM
Dryer will not heat during timed drying; will heat for short time while auto drying mg13nj Dryer Repair 9 03-22-2008 11:40 AM
Heat but not drying, seems like heat is not blowing good Papa1 Dryer Repair 2 10-07-2007 10:11 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
